[?]: write the external tags to Wincc SQL server
valmet
Post by valmet » Thu Sep 06, 2007 7:21 am
Hello
I want write the external tags to sql server every ten second.How am ı make?
rataman
Post by rataman » Fri Sep 07, 2007 4:22 am
You have two choices:
1) Use Tag Logging, it is fast and easy, read the help or
2)Use a global vb script with a cyclic trigger of 10 seconds and use this code:
Sub ConnectDB
Set gocn = CreateObject("ADODB.Connection")
Set SQLresult = CreateObject("ADODB.Recordset")
'CONNECT TO SQLSERVER
gocn.open "Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=YOURDATABASE;Data Source=.\WinCC"
sSql = "yoursqlqueryhere"
SQLresult.open sSql, gocn, 1
gocn.close
Set gocn = nothing
Set SQLresult = nothing
end sub
valmet
Post by valmet » Sat Sep 08, 2007 6:46 am
Thank you for oyur information
I try to Tag Loggin but ı dont connect to SQL ,ı dont see the sql option.I think ı dont make some adjustment can you help me ? :oops:
rataman
Post by rataman » Sun Sep 09, 2007 2:19 am
You should not do any adjustment, just go to tag logging from wincc explorer, create a new file, add tags and you are done, no need to configure any connection for archiving on local sql server.
valmet
Post by valmet » Sun Sep 09, 2007 4:01 am
:P thank you for your imformation .And can ask one question more.CAn I sellect my table in SQL side.Wincc sellect ıts table.But ı want to use diffrent table.For exp.;
New_Tag1 is wincc tag.Iwant write this tag value every ten second to "Trend" table in SQL side.
rataman
Post by rataman » Sun Sep 09, 2007 5:56 pm
Use the VB code to use your own databases.
I made a few projects accesing Oracle and SQL , but i dont have them on hand till next week.
Greetings
valmet
Post by valmet » Wed Sep 19, 2007 8:28 am
Where can i found information about this subject
Galli
Post by Galli » Wed Sep 19, 2007 10:45 am
I have the sample program SQL WinCC..
But I don't know wheter this what you looking for...
Here the link ..
http://domain945847.sites.fasthosts.com/downloads.asp
valmet
Post by valmet » Fri Oct 05, 2007 8:56 am
thank you
Can ı found ext prg for this job
enraptured
WinCC SQL information
Post by enraptured » Wed Oct 24, 2007 10:11 am
Here is a website that has some examples of SQL and other things.
http://www.wincc.net/
http://www.allottware.co.za
