Request: TwinCat Key or a other goot SoftPLC
другие контроллеры
Sallos
Post by Sallos » Wed Sep 05, 2007 11:06 am
i'm searching for a TwinCat Key or a other good SoftPLC
TwinCat SysID: 0489-9F5F-280
I hope you can help me.
Sallos...
PsI-On
Post by PsI-On » Wed Sep 05, 2007 11:22 am
Hi Sallos,
I'm also looking for something like this too :?
I have the earlier version of Twincat, to which the serials are on this site. I couldn't get it to work, something about RTIME errors etc...
I'm thinking it just doesn't like winxp sp2 or something like that.
If I find anything I'll let you know.
-PsI
Sallos
Post by Sallos » Wed Sep 05, 2007 11:30 am
i have the TwinCat demo (30Days) on a Win2000Pro one CPU System and its Works.
Sallos
PsI-On
Post by PsI-On » Wed Sep 05, 2007 11:52 am
Interesting!
What version of Twincat are you using?
-PsI
Sallos
Post by Sallos » Wed Sep 05, 2007 11:58 am
Version: v2.8.0 Build739
I need a KeyGen.....
PsI-On
Post by PsI-On » Wed Sep 05, 2007 12:08 pm
Hi, both of these keys worked for me with this version of twincat.
C850-2854-3D19-DD40
and
C850-2854-3D19-9E40
-PsI
Sallos
Post by Sallos » Wed Sep 05, 2007 12:13 pm
Thanks it works....
RegVersion: TwinCat-PLC
TwinCat-280
Supports this version Modbus?
PsI-On
Post by PsI-On » Wed Sep 05, 2007 12:32 pm
I don't have the modbus library for it but I do have the opc server, you can setup DX exchange server with another OPC server like kepware for modbus.
-PsI
Sallos
Post by Sallos » Wed Sep 05, 2007 12:56 pm
Suports Twincat other Librarys, on www.wago.com are many Libs.
First i load the InfoSys.
Have you Libs for Ethernet/IP i will use Wago Copper for E/A (MODBUS or Ethernet/IP)
PsI-On
Post by PsI-On » Wed Sep 05, 2007 1:07 pm
I don't have any libs for anything yet :(
I designed my own modbus/tcp IO cards, I thought the only way to connect them to twincat was with OPC, or their modbus library.
Is there another way?
-PsI
Sallos
Post by Sallos » Wed Sep 05, 2007 1:19 pm
Her look at this http://www.wago.com/wagoweb/documentation/index_d.htm
There are any Libs for Wago PLC, i will test at Twincat.
PsI-On
Post by PsI-On » Wed Sep 05, 2007 1:25 pm
This version of Twincat definately does not work with WinXP SP2, because multi processor kernel is installed.
I'm downloading win2k...lol...That was harder to find than twincat :shock:
Sallos
Post by Sallos » Wed Sep 05, 2007 4:18 pm
PsI-On
Post by PsI-On » Thu Sep 06, 2007 9:55 am
I'm using V2.8 build(739)
It's an old one :(
Sallos
Post by Sallos » Fri Sep 07, 2007 10:11 am
Mhr Twincat don't works with Wago Coppler 750-841 :(
No one have a other good SoftPLC for Windows or Linux???
