http://www.filefactory.com/file/4ed942/ or http://plcforum.uz.ua//NI ... .part1.rar
http://www.filefactory.com/file/7fbd29/ or http://plcforum.uz.ua//NI ... .part2.rar
http://www.filefactory.com/file/87306a/ or http://plcforum.uz.ua//NI ... .part3.rar
![Image](http://img293.spamm.us/img293/7116/nimotionkh8.jpg)
Company National Instruments has officially presented NI Motion Assistant 2.0, the updated version of the interactive program of modelling of control systems for one-axial and multiaxial coordinate systems.
Designers and developers of such systems, using new ON from NI, now can import files CAD and some other using popular format DXF. Direct access to structures of the user will allow to save time essentially.
The new convenient interface facilitates embedding of structures of movement in programs of logic controllers NI Compactrio, allows to generate a code plug-in PCI/PXI for controllers of movement.
After preservation of a structure of movings in DXF or a compatible format for CAD, Autocad or Solidworks, NI Motion Assistant 2.0 keeps individual options in a XML-format without additional code conversion. In the further the user can use the written down XML-files for work with National Instruments Labview, appendices of family With and some other. Except for an opportunity of import of structures of parameters of movement NI Motion Assistant 2.0 allows to convert them in codes C and in appendices NI Labview.
The program carries out calculations of trajectories of moving for different speeds, in view of linear, triangular and circular interpolation from a S-curve of dispersal and braking for reduction of vibrations and increase in service life of the machine or the machine tool. NI Motion Assistant 2.0 supports graphic point-and-click the interface with 3D visualization, and is the powerful tool of creation of appendices and programs of the control and management of movings with step-by-step and servo-drivers and piezoactuators.
Program NI Motion Assistant 2.0 engineers - developers of machines and mechanisms for exact processing metal (it is sharp, an engraving, drilling), a tree will appreciate, glasses, and others. Now for them it becomes easier to program machine tools and machines for laser cutting fabrics and plastic; the equipment for exact operations in microelectronics and manufacture of semi-conductor technics; the medical and scientific equipment.
Description in Russian wrote:Компания National Instruments официально представила NI Motion Assistant 2.0, обновленную версию интерактивной программы моделирования систем управления для одно- и многоосевых координатных систем.
Конструкторы и разработчики таких систем, используя новое ПО от NI, теперь смогут импортировать файлы CAD и некоторые другие используя популярный формат DXF. Прямой доступ к профилям пользователя позволит существенно экономить время.
Новый удобный интерфейс облегчает встраивание профилей движения в программы логических контроллеров NI Compactrio, позволяет генерировать код plug-in PCI/PXI для контроллеров движения.
После сохранения профиля перемещений в DXF или совместимом формате для CAD, Autocad или Solidworks, NI Motion Assistant 2.0 сохраняет индивидуальные настройки в XML-формате без дополнительной перекодировки. В дальнейшем пользователь может использовать записанные XML-файлы для работы с National Instruments Labview, приложениями семейства С и некоторыми другими. Кроме возможности импорта профилей параметров движения NI Motion Assistant 2.0 позволяет конвертировать их в коды C и в приложения NI Labview.
Программа выполняет расчеты траекторий перемещения для разных скоростей, с учетом линейной, трапецеидальной и круговой интерполяции с S-кривой разгона и торможения для уменьшения вибраций и увеличения срока службы машины или станка. NI Motion Assistant 2.0 поддерживает графический point-and-click интерфейс с 3D визуализацией, и является мощным инструментом создания приложений и программ контроля и управления перемещениями с шаговыми и сервоприводами и пьезоактуаторами.
Программу NI Motion Assistant 2.0 оценят по достоинству инженеры – разработчики машин и механизмов для точной обработки металла (резка, гравировка, сверление), дерева, стекла, и т. п. Теперь для них станет проще программировать станки и машины для лазерного раскроя тканей и пластика; оборудования для точных операций в микроэлектронике и производстве полупроводниковой техники; медицинскую и научную аппаратуру.
