I want to install the update step 7 v5.4, and lost the disc (a) with the license, then I want to know if disc (a) is going to request nel during the installation or takes to the license directamende of the hard disk
thanks for help me
[?]: install step 7 v5.4 without license
ausnis
For Upgrade from Step7 v5.3 to Step7 v5.4 need upgrade Yellow Disk or Yellow USB Stick with Upgrade key v5.4
or see http://plc.net.ru/viewtopic.php?t=218
ausnis
ok
thanks for the aid.
but your you think that when you install step 7 v5.4 and it requests the license to you, is possible to be sent from another computer with the program automation license manager, taking the key of that odenador because I do not have the yellow disc, or you do not have that option?
http://support.automation.siemens.com/W ... n/19020864
License Key Meaning
Single License Unlimited use on any one computer.
Floating License Unlimited use on any one computer or via the network.
Rental License Limited use as stipulated in the rental contract.
Trial License Limited use (max. 14 days) for tests and for validating (with disclaimer).
Upgrade License An Upgrade License converts a license for an earlier version x to a license for version >x+... .
saad rashed
Re: [?]: install step 7 v5.4 without license
key for Step 7ausnis wrote:I want to install the update step 7 v5.4, and lost the disc (a) with the license, then I want to know if disc (a) is going to request nel during the installation or takes to the license directamende of the hard disk
thanks for help me
http://plc.net.ru/viewtopic.php?p=11212#11212
