[?+]: crack for Concept 2.6
другие контроллеры
fernando
Post by fernando » Wed Aug 22, 2007 9:03 pm
Schtiel:
I Have to say Thanks for the link of Concept Soft 2.6 and for the link of the concept manual, it´s very useful. The software is in French, and with the patches it`s working. I have to quest, if you have this software in Spanish or maybe give me a solution for translate with the patches French/Spanish or a link for download, full.
This question is because I´m from Chile and my native language is Spanish. and I´m know just a little French.
Well, Thanks Again.
Schtiel
Post by Schtiel » Thu Aug 30, 2007 6:52 am
scaramanga wrote:i would love a link to english concept 2.6 with ser#.please
I don't have a Spanish version of Concept 2.6, I have an English one.
Serial Number:
Link deleted by TimeOut
scaramanga
Post by scaramanga » Thu Aug 30, 2007 10:04 pm
thanK you Schtiel:
i would also like the software to go along with the key :)
here is a link for the spanish version
http://plcforum.uz.ua//CO ... 6.rar.html
cheers
Most wrote: English
http://plcforum.uz.ua//co ... L.rar.html
copy and replace the files in ..aut for folder concept.
not work in OS Vista
most
Post by most » Sat Apr 19, 2008 3:20 pm
ahmed yousri wrote:i download english version but its trial to 14 day if any one have a crake or serial no
you have to read what posts says
only copy and replace the file Authorcc.dat in forder "concept_aut" for folder of instalation "concept"
regards
most
Post by most » Sun Apr 20, 2008 8:30 am
if you are using SO vista, this file http://plcforum.uz.ua//co ... L.rar.html
not work.
I tested now in XP and everything functions, i open and and I closed some times. OK
most
ahmed yousri
Post by ahmed yousri » Sun Apr 20, 2008 11:47 am
i will explain what i did ,and please refer to my error
first download file from
second replace the file Authorcc.dat in forder "concept_aut" for folder
third install the program
after install , there is a message appeared say the version expired so you must register
Schtiel
Post by Schtiel » Sun Apr 20, 2008 12:04 pm
1. Copy Authorcc.dat to C:\
2. Launch authorization wizard
3. Select "transfer from drive C:\"
ahmed yousri
Post by ahmed yousri » Sun Apr 20, 2008 12:25 pm
thanks for your replies ,program work ok :oops: :oops: :oops:
most
Post by most » Sun Apr 20, 2008 1:59 pm
ahmed yousri wrote:i will explain what i did ,and please refer to my error
ahmed yousri wrote:thanks for your replies ,program work ok :oops: :oops: :oops:
I am happy for you.
your error was in the second sequence that you made.
second = install
third = copy autorization for folder
Schtiel wrote:1. Copy Authorcc.dat to C:\
3. Select "transfer from drive C:"
Schtiel
I think that autorization wizard does not work in this version.
regards to all
mseena
help on Concept V2.6
Post by mseena » Fri Jun 12, 2009 11:16 am
Can any help on Concept V2.6.
I am getting run time error #339 During authoriz run and Message Qoute:
"SMTP.OCX or dependies not regd correctly or mising file"".
Will it work with OS Windows XP SP3 or it requires SP2..
Thanks a lot in advance...
Schtiel
Re: help on Concept V2.6
Post by Schtiel » Fri Jun 12, 2009 1:28 pm
mseena wrote:"SMTP.OCX or dependies not regd correctly or mising file"
1. Check if SMTP.OCX is in your WINDOWS\SYSTEM32 directory
2. Run the following command: REGSVR32.EXE %WINDIR%\SYSTEM32\SMTP.OCX
mseena wrote:Thanks Schtiel, No I searched for the file I could not found in the system32 dir. (even I searched including show hidden files also)
how to proceed.. Thanks
You should get this file somewhere and put it into your system32 directory, and then register it.
Try to find it on the another PC or in google.
If you can't find it, I will upload it on Monday.
Schtiel
Post by Schtiel » Fri Jun 19, 2009 7:00 am
mseena wrote:Schtiel, can you pl upload the smtp.ocx file I tried to download from net some how i was not able to find right file and i using personal laptop, could not get from other pc.
Here it is:
http://plcforum.uz.ua//smtp.ocx
or
http://narod.ru/disk/11607297000/smtp.ocx.html
mseena
Post by mseena » Fri Jun 19, 2009 8:13 am
Thanks Schtiel, problem sloved :D ....
Schtiel
Post by Schtiel » Tue Aug 04, 2009 7:36 am
Can you post file Autoriz for me?
Thanx in advance,
check this link:
viewtopic.php?p=10607#10607
jerkoffman43
Re:
Post by jerkoffman43 » Wed Oct 23, 2013 6:44 am
Could someone please reupload this smtp.ocx file? (oo)
I have same issue as mseena
dankor182
Re: [?+]: crack for Concept 2.6
Post by dankor182 » Tue Aug 18, 2020 7:17 pm
2020 and still working with SP7, thank you all for make this possible (suc)
xubaer
Post by xubaer » Sat Aug 22, 2020 8:47 am
Thanks to all......
mshamim13
Post by mshamim13 » Sat Nov 19, 2022 6:04 pm
hi, can you please send me link for concept 2.6 with activation code.
thanks,
mshamim13
Post by mshamim13 » Sat Nov 19, 2022 6:06 pm
thanks,
