[?]: Problem with License Key SIFLPCS7TT0700
sttrue88
Post by sttrue88 »
Dear Friends,
I have a problem with the authorization of PCS7 which I installed from Simatic_EKB_Install_2007_06_12.exe file, and I have a problem only with the license SIFLPCS7TT0700, PCS7RC (153600) and the strange this is when I check this license key with automation license manager v3.0, it said the license is OK but when I work with wincc, I faced with the error window .please help me about this strange problem.
Thanks in Advance
Sttrue80
See text of log files from WinCC\Diagnose folders.
You need install any SIFLA9WRC*0602 key for WinCC.
SIFLPCS7TT0700 is a Trial bundle key.
sttrue88
Post by sttrue88 »
Dear Friend,
Thank you so much for your guidline ,I deleted the mentioned license and install the license you said, but when i start the wincc i have an error again,in this time the error is missing of SOME NEW license with this explanation :"A9WRP?602" AND "A9WCP?602",so could you please help me again how can i install these license on my pc?because these license are not in EKB package.
Thanks in Advance.
Sttrue80
For WinCC v6.2 2 new licenses are let released: WRP (ex WRT) - Runtime only, WCP (ex WRC) - Configure and Runtime
At me they while are not present - therefore they are not present in a set.
Licenses WRC normally work for me.
Для версии 6 выпущены 2 новые лицензии: WRP - Runtime, WCP - Configure and Runtime
У меня их пока нет - поэтому их нет в наборе.
У меня нормально работают лицензии WRC.
sttrue88
Post by sttrue88 »
Dear Comod,
Thank you again for helping me,
but the question is remained how can i make or receive this license ?
i need these license ,i totally appreciated you ,if any way show me to having these license?is it possible to send me these license key ?
Thanks in Advance,
sttrue80
I have and use EKB_Install, but my WinCC v6.2 work without problems - try to install ALL required key.
Send me log files from WinCC\Diagnose folder
sttrue88
Post by sttrue88 »
Dear Comod ,
Thank you for helping me,I appreciate your kindness,
I think the problem is I use the PCS7 package and you use the WINCC package and this the reason you donot have this problem,any way ,I just want to send the diagnose folder to you as Zip file but I don't know your email.
could you please give me your email,in this web site i don't know how can i send the file to you ,it seems there is no place for uploading the file in this site.i am waitning for your email,
Thank you so much,I hope <i can compensate your kindness.
Sttrue80
sttrue88 wrote:I think the problem is I use the PCS7 package and you use the WINCC package and this the reason you donot have this problem,any way...
I have and use PCS7 v7.0 and WinCC v6.2 in different comps without problems.
sttrue88 wrote:I just want to send the diagnose folder to you as Zip file but I don't know your email.
Press button "E-Mail" Image
sttrue88
Post by sttrue88 »
Dear Comod,
Thank you again ,but the E-mail button is not functioning,I can't click on it.
Please check the button.
Thanks in Advance
Sttrue80
This is your
sttrue88 wrote:08/14/2007 20:44:56 Control Center - Demo Mode ConfigurationSystem enabled -
08/14/2007 20:44:56 NoLicense CS | Name of License = A9WCP?0602 | Text of License = Simatic WinCC RC PO (Runtime + Engineering) | Exists = No |
08/14/2007 20:44:56 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = A9WCP?0602 | Text of License = Simatic WinCC RC PO (Runtime + Engineering) |
08/14/2007 20:44:57 NoLicense ED | Name of License = A9WCP?0602 | Text of License = Simatic WinCC RC (Runtime + Development) | Exists = No |
08/14/2007 20:44:57 Control Center - Demo Mode Editors enabled -
08/14/2007 20:44:57 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = A9WCP?0602 | Text of License = Simatic WinCC RC (Runtime + Development) |
08/14/2007 20:44:57 Control Center - Demo Mode ConfigurationSystem enabled -
08/14/2007 20:45:02 Control Center - Demo Mode Runtime enabled -
08/14/2007 20:45:02 NoLicense RT | Name of License = A9WRP?0602 | Text of License = Simatic WinCC RT PO (Runtime) | Exists = No |
This is my from PCS7 with project >512 Archive Tags
CoMod wrote:08/15/2007 13:11:47 InitLicense RT | AppName = OptRT:CHIPCARD | CycleCheck = no | NameForMessageBox = | Name of License = SISLA1WPC40602 | Text of License = WinCC Chipcard |
08/15/2007 13:11:47 ExitLicense RT | AppName = OptRT:CHIPCARD | CycleCheck = no | Name of License = SISLA1WPC40602 | Text of License = WinCC Chipcard |
08/15/2007 13:11:51 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRC70602 | Text of License = WinCC RC (262144) | Relevant Limit = 0000262144 |
08/15/2007 13:11:51 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = SIFLA9WRC70602 | Text of License = WinCC RC (262144) | Relevant Limit = 0000262144 |
08/15/2007 13:11:59 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRC70602 | Text of License = WinCC RC (262144) | Relevant Limit = 0000262144 |
08/15/2007 13:11:59 InitLicense RT | AppName = AppRT:Mcp_Server | CycleCheck = yes | NameForMessageBox = | Name of License = SISLA9WSEC0602 | Text of License = WinCC Server |
08/15/2007 13:11:59 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFCY9WTGX06003 | Text of License = WinCC Option Archive | Relevant Limit = 1000...
sttrue88
Post by sttrue88 »
Dear Comod,
Thank you, But I don't get your intention,because i just need the solution for this licenses,is there possibility for sharing the new license ?
could you please guide me what should i do for my probelm? is it possible i have a screen shot from your ALM license list ?
Thanks in Advance
Sttrue80
sttrue88
Post by sttrue88 »
Dear CoMod,
I check your license log but I remind again when I open the wincc from my Simatic Manager that means when I use PCS7,I have this problem. But these logs that you send to me just have the wincc license but the problem is with the wincc new license as I say in my previous post. I know you get my problem but please show me a solution or send me some necessary license as you know.
Thanks in Advance.
Sttrue80
