S7-Technology V2.0 + SP1
The new s7
Post by The new s7 »
1. Free Highspeed-Download for the S7-Technology V2.0 + SP1 Update Archive from Siemens Support Page (429 MB)
http://support.automation.siemens.com/W ... /21713863/
S7_Technology_V20_SP1.zip?func=cslib.csFetch&nodeid=21722347
2. Download the Updatetrick under:http://files.cavalka.net
3. You also needed WIN 2000+SP3 or Win XP Professional+SP1 and Step7 V5.3 SP1 or higher.
4. Befor you run the S7-Technology Setup, dubblelclick left Mousebottom on the Regfile "1.Step" an accept with Yes.
5. Run the S7-Tech Setup; you get the message "Please deinstall the S7-Techversion...." Accept with OK, but no restart you PC.
6. Dubblelclick left Mousebottom on the Regfile "2.Step" an accept with Yes. (This Regfile removes the first Regmassage).
7. Run the S7-Technology setup again...
8. This Programm its an "Addon" it needed no License Key.
No Crack ,only a friendly Trick.
The new s7
correction
wally
The new s7
Post by wally »
There is some problem with Siemens link to download S7-Technology V2.0 + SP1 Update .
wally
BigFile
Post by BigFile »
Only one problem - file is big 439.853 KB .
I try today.
http://support.automation.siemens.com/W ... Technology &SearchArea=downl&id=21713863&F11Marker=&siteid=&query2=&modelled=
xiong1
Post by xiong1 »
Will you upload the Updatetrick to the forum, thank you very much!
adress
S7-Technology
Post by adress »
check this adress for the updatetrick ;
http://files.cvalka.net/index.php?actio ... me=S7-Tech V2.0SP1.zip&directory=Simatic&
