hello.
is it possible to use the crack for eplan 5.7 or P8 with my own serial.
i only want to work without my hardlock.
want to use the original serial.
because you see the number in the options from the sites and my costumers must see it.
[?]: Use the ePlan crack with my own serialnumber.?!
Garog
Schtiel
Try to do the following:
1. Create backup of your original serial number file (SN-XXXX.EPL in your Windows directory)
2. Apply crack from this topic. It will patch file Lclic32.dll to remove hardlock check and put it's own serial SN-.EPL to open all Eplan options.
3. Delete SN-.EPL from your Windows directory
4. Put your original SN-XXXX.EPL into your Windows directory
Hope it will work
Hope it will work
Garog
