Request: SP1 for Drives ES 5.4 basic
beertje
Post by beertje » Mon Jun 25, 2007 1:09 pm
Has anyone servicepack 1 to upgrade my Drive ES 5.4 basic?
http://support.automation.siemens.com/W ... n/25432872
I should need it to work with the new firmware 2.1 of the Sinamics G120.
If possible also the servicpack for Drives ES Simatic 5.4.
Thanks.
beertje
Servicpack 1 for Drive ES basic 5.4
Post by beertje » Mon Jul 09, 2007 9:16 pm
Hey,
I am desperately searching for servicepack 1 for Drive ES basic 5.4.
Problem is I cannot connect anymore with the Siemens G120 drives with the newest firmware. Does anyone have this servicpack, or is there another solution?
brave_eagle
Post by brave_eagle » Wed Jul 11, 2007 2:31 am
Download last version Starter then install it
beertje
Post by beertje » Wed Jul 11, 2007 11:56 am
Thanks for your support, but the problem is I have Scout V4.0 installed, which is not compatible with Starter. Do you have a solution for that?
