hi friends. I have try to configure a CPU 317 T but this device isn'present into harware catalog. I have update a catalog from siemens site, but not exist.
Anyone have a idea ?
I need a add on package ?
tank you
[?]: HOW TO CONFIGURE A CPU 317 T
Hi Buddy from the 317T manual it reads
Configuring and programming
The Technology CPU is configured and programmed completely in STEP 7 (Version 5.3 SP3
and later) and optional package S7-Technology V3.0 (the S7-Technology optional package
is integrated after installation inSTEP 7 ).
STEP 7 HW Config is the tool used to configure all hardware components of the system (e.g.
to create subnets on the two interfaces MPI/DP and DP(DRIVE)) including the drive
equipment.
You will need optional package S7-Technology to parameterize the so-called "technology
objects", e.g. axes, cams, output cams and probes.
The objects are parameterized in specially provided screens. The technology object data are
stored in data blocks for use by the STEP 7 user program.
S7-Technology also includes a library containing PLCopen-compliant standard function
blocks which are used to program the motion control tasks themselves. You call these
standard FBs in your STEP 7 user program.
STEP 7 languages LAD, CSF and STL and all the required engineering tools, e.g. S7-SCL or
S7-GRAPH are provided to enable you to create the STEP 7 user program (incl. motion
control tasks).
Manual link : http://support.automation.siemens.com/G ... d0=4000024
Hope this helps
##~FlashY~##
equipment.
control tasks).
Hope this helps
##~FlashY~##
