[?]: problem with User Archives set up
krcedinac
Post by krcedinac » Tue Jun 12, 2007 12:59 pm
Hello to all,
I have been trying to set up User Archives in WinCC (add in the existing project) by following the wizard and reading the manual. But, what ever I do I always have same message in the log file when I start the run time:
[06/12/07 12:10:24] CUARuntime::Connect to RT database failed
[06/12/07 12:14:40] CUARuntime::Connect to RT database failed
Can somebody please tell me what is the problem?
WinCC v6.0 SP4
Thank you in advance...
frankw
Post by frankw » Sat Jun 30, 2007 2:57 am
Yes, the same problem with WINCC v6.2 User Archive when i test the Wincc6 Demo project:
Error while setting up connection to User Archive Server!
But it was OK with Wincc 6.04.
what is wrong?
