REQUEST+?:PATH Plus or PFAD PLUS and S7-CHARTS
frankw
Post by frankw » Tue Jun 05, 2007 2:34 am
FIRST THANKS TO FLASHY:
Does anybody have the PATH Plus configration program for MASTERDRIVES?
also named SIMOVERT MASTERDRIVES CONFIGURING TOOL PFAD PLUS: 6SW1710-0JA00-2FC0
One question:
in the Simatic EKB Key Install_07_05_25,I find the key for S7_Charts, what is the function of S7_Charts? Before, one Step7 project request this component, i think it maybe CFC, so it is wrong!
Does anybody have the S7_Charts?
frankw
Post by frankw » Thu Jun 14, 2007 1:41 am
Frequency converters SIMOVERT MASTERDRIVES
Configuring with PATH Plus
With the PATH Plus program, three-phase drives fed by frequency converters for SIMOVERT MASTERDRIVES Vector Control and Motion Control units can be configured easily and quickly.
The program is a powerful engineering tool which supports the user in all stages of configuration – from power supply to the motor.
Menu-guided selection and layout of the frequency converters enable the system components and the motors necessary for a specific drive task to be determined. Automatically displayed information makes fault-free planning possible.
A comprehensive help system also supports the first-time user of the program.
PATH Plus provides a logical and easy-to-use dialog procedure to guide the planning engineer towards a reproducible and economically efficient drive configuration, starting with the mechanical requirements of the machine and the drive task involved.
The technical data of the frequency converters and motors, the selected system components and the necessary accessories are listed in detail.
PATH Plus enables drives to be configured on the basis of a load characteristic or a load cycle and enables planning of applications such as the following:
traversing and hoisting gear
slewing gear
spindle drives
center winders
thrust crank.
PATH Plus also includes a comfortable graphic display for showing
torque, speed, output, current, velocity and acceleration versus time and
torque versus rotational speed.
Supply harmonic disturbances can also be calculated and graphically displayed.
The planning and configuring results can be stored, printed out or copied to other user programs via the clipboard.
PATH Plus is available with either a German or English user interface.
You can download the demo version of PATH Plus from the following Internet address:
http://www.siemens.com/motioncontrol (products&systems/drive systems/software).
If you need the full version of PATH Plus, contact your local Siemens office and quote the following order number:
6SW1710-0JA00-2FC0
