I need soft "global drive control"
help pls...!
[LINK]: I need Lenze soft "global drive control"
Get actual Update 4.10 from manufucktors page.
http://akb.lenze.de/AKB-englisch/infopo ... enDocument
Info: there is also a SP1 and a GU8...
Create on your PC the following structure
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
As files use any file and rename it to the name showen above.
Install update - use parallel installation.
Install SP1 and GU8
Delete helpfolders
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
finished
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
Install SP1 and GU8
Delete helpfolders
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
finished
if you want Global Drive Control Easy v4.5 say something or download with emule (the file is good but not test with hardware)
ed2k://|file|LENZE%20-%20Global%20Drive%20Control%20Easy%20v4.5.zip|40840829|B3DE148C36AA360D0FE5A409EFA7C3CA|h=SYANMS2YFPVMCT3CP7RO62VE27SAAAYR|/
also i have GLOBAL DRIVE CONTROL - V 4.10 SP4 with serial
120760 KB
http://plcforum.uz.ua//L ... .1_SP4.rar
Quote:
I need GSD
http://support.automation.siemens.com/WW/view/en/113498
http://support.automation.siemens.com/W ... n/23372259
better is to enter in the forum Siemens (register free) and a search for GSD
most
120760 KB
Quote:
I need GSD
most
GDC
This link informed by most
I downloaded 2 week ago.
planetcla10
planetcla10
Re: [LINK]: I need Lenze soft "global drive control"
CAN you plz share it again gdc v4.10
Global Drive Control V4.14.1 is freely available on Lenze official website here.
And no serial is needed to use this version.
Direct link: GDC V41401.zip
