[?]: Problems with InTouch 9.5
Владимир
Post by Владимир »
After installation of program InTouch the Manager of projects is started only.
At start writes the accepted license.
At attempt to open any project in Maker or Viewer nothing occurs.
That is the manager is closed and more any appendix does not open.
All simply dies...
Prompt where a glitch.
Windows XP SP2
in Russian wrote:После установки интача запускается только Менеджер проектов. При запуске пишет принятую лицензию. При попытке открыть проект (любой) в Мейкере или Вьювере ничего не происходит. То есть менеджер закрывается а больше никакое приложение не открывается. Все просто умирает...
Подскажите где глюк.
На машине стоит Винда ХР Про СП2
ian
Post by ian »
Nobody an idea what's wrong?
I just installed Intouch9.5 and i notice the same problem. I hope someone has a sollution.
Umencho
Post by Umencho »
Hi
What kind of antivirus programm do you use. This problemm appears with NOD32 antivirus prograam. Remove the antivirus an try again. With Avast Professional, Intouch 9.5 working properly.
Best regards
umencho
nautical
Post by nautical »
I also had problem with Intouch 9.5 before and final I re-install it (of course you must perform a unistall and re-boot the system again!!) with un-select to install the System Config Utilities, and then your installation will be completed with nothing wrong and they works fine for me for months ago!!!!!!
ian
Post by ian »
I have NOD32 and i won't remove it because i think it's the best antivirus software, so i tried the solution from nautical but that didn't help me. I will wait for another solution because uninstalling NOD32 isn't an option.
Blade_007
Post by Blade_007 »
ian wrote:I have NOD32 and i won't remove it because i think it's the best antivirus software, so i tried the solution from nautical but that didn't help me. I will wait for another solution because uninstalling NOD32 isn't an option.
Disable IMON.
ian
Post by ian »
I disabled IMON but with no result, I can start the Intouch "Application manager" but when i try to open any application or start a new application, the manager closes and i see in the task manager of windows that the application wm.exe is running but i see nothing on my screen.
the same with windowviewer, in the taskmanager view.exe is running but i see nothing on my screen.
fubrus0
Post by fubrus0 »
Use WinSockXPfix always after NOD32 update system (not virus data base). IMON have to be switch off.
Or stop Wonderware Log service.
ian
Post by ian »
fubrus0 wrote:Use WinSockXPfix always after NOD32 update system (not virus data base). IMON have to be switch off.
Thank you very much, WinSockXPfix did the trick and Intouch works fine now.
Greetings,
Ian
prohos
Re: [?]: Problems with InTouch 9.5
Post by prohos »
Hi there!
My suggestion for you is to try to fix your problem, maybe perform a scan, but you need to use a high quality antivirus software, so you make sure you do that. You will fix it, anything has a solution.
