[LINK]: WinAC RTX 2008 SP1 and 2005 SP1/SP2 with ODK4.2
Link
Forum Community
Forum Community
Contact:
Post by Link » Wed May 16, 2007 6:50 am
http://narod.ru/disk/2044349000/WinAC_R ... 2.zip.html
or
Link_is_Dead :(/Wi ... .part1.rar
Link_is_Dead :(/Wi ... .part2.rar
Link_is_Dead :(/ODK_41.rar
get hotfix 3 for WinAC RTX 2005SP1 from Siemens web site:
http://support.automation.siemens.com/W ... P1_HF3.exe
Ardence RTX RT & SDK PAC
email:
winac@siemens.com
PAC#
5224-PAC-00477-72153-89411
Download v6.5 SP1 RTX SDK from
Link_is_Dead :(/A ... nd_SDK.zip
or
http://narod.ru/disk/2043845000/Ardence ... K.zip.html
17 mb
if you program with WinAC ODK v4.1 for RTX
Use the same email and PAC#
key sifla1wrtx0402.ekb from EKB_Istall
http://support.automation.siemens.com/W ... n/22826076
Siemens wrote:The SIMATIC WinAC Basis software and RTX support only the CPs CP5611, CP5611-A2, CP5613 and all versions of CP5613-A2 as IF module.
WinAC Basis and RTX do not support any other CPs as IF module.
The PCMCIA cards CP5511 and CP5512 are not supported either.
Contact:
WinAC RTX 2005 SP2
Post by CoMod » Mon Nov 26, 2007 8:04 pm
WinAC RTX 2005 SP2
http://support.automation.siemens.com/W ... n/15227402
http://support.automation.siemens.com/W ... n/26992994
http://support.automation.siemens.com/W ... 05_SP2.exe
( 66028 KB )
Key SISLA1WRTX0403.EKB
Key name : WinAC RTX
Family : SIMATIC WinAC
Version number : 4.3
Link
Forum Community
Forum Community
Contact:
Post by Link » Tue Dec 30, 2008 3:36 pm
WINAC RTX V4.4 (2008)
Link_is_Dead :(/W ... X_v4.4.RAR
140 mb
Link_is_Dead :(/S ... TX0404.RAR
http://support.automation.siemens.com/W ... n/33400780
If you wish to install WinAC RTX on a Single-Core microprocessor with installed Multiprocessor HAL
and running without Hyperthreading
or with Hyperthreading switched off ,
WinAC RTX will abort installation with the error message
Error wrote:"Unable to install RTX ... Runtime on this system ...".
In this case you must first install a suitable "ACPI Uniprocessor PC" HAL before you can install WinAC RTX.
SIMATIC WinAC RTX 2008 ServicePack 1
http://support.automation.siemens.com/W ... e/33563717
include
http://support.automation.siemens.com/W ... e/15227402
http://support.automation.siemens.com/W ... 08_SP1.exe
and
http://www.intervalzero.com/support.htm
http://www.intervalzero.com/downloads/r ... 1Setup.zip
RTX 8.1 SDK
http://www.intervalzero.com/rtx_purchased.htm
http://www.intervalzero.com/downloads/r ... untime.zip
---------- FAQ --------------------
frankw wrote:How to make V4.4 available in the catalog list of STEP7 Hardware Configration, WinAC2008 not installed in the same PC.
WinAC v4.4 2008 is only for STEP7 V5.4 SP4
Update last HSP STEP 7 Hardware Support Packages (HSPs - Stand: 11/2008)
Online from HW Config
offline from Support http://support.automation.siemens.com/W ... n/23183356
Contact:
Post by CoMod » Wed Dec 31, 2008 8:14 am
frankw wrote:CPU load 100%, the process is s7wlpapx.exe, OS is WinXP SP3,
before and after RTX SP1 installation,
what is wrong?
wrong? Need Dual core CPU - one core for WinAC dedicated mode.
Intel® Core™ 2 Duo processor technology with SIMATIC WinAC installation options for SIMATIC WinAC
on SIMATIC PCs with Intel® Core™ 2 Duo processors (shared and dedicated mode).
Performance comparisons for SIMATIC WinAC RTX and SIMATIC WinCC flexible
on an Intel® Core™ 2 Duo processor and a single-core processor.
* CPU load
* Update time
* Picture opening time
See FAQ
Why does the Windows application load increase to 100% after installing WinAC RTX 2008?
http://support.automation.siemens.com/W ... n/34665850
Why does the installation of WinAC RTX 2005 (SP1) and of WinAC RTX 2008 abort?
http://support.automation.siemens.com/W ... n/29001277
When installing WinAC RTX 2005 and WinAC RTX 2008 on SIMATIC PCs of the "B" generation with Intel Celeron processor and preinstalled Microsoft Windows XP Professional or XP embedded operating system, the following installation fault occurs...
amarillo
Post by amarillo » Mon Feb 09, 2009 3:24 pm
No PAC for RTX SDK?
Does anybody have a PAC for SDK?
RTX-RT PAC is builtin Ardence.ssf silent installer but what about SDK?
I hate to debug this InstallShild script crap
Link
Forum Community
Forum Community
Contact:
Post by Link » Fri Sep 25, 2009 12:50 pm
greeds_
Re: [LINK]: WinAC RTX 2008 SP1 and 2005 SP1/SP2 with ODK4.2
Post by greeds_ » Fri Feb 25, 2011 10:57 am
For Ardence RTX v8.1 SDK try to use this serial key: 5484-PAC-58204-59086-16484 with e-mail a@a.a
Best regards!
