Hello
there some Hotfixes for Step7 5.4 SP1.
You can get this hotfixes only at request by customer support.
Please can sombody provide this HotFixes?
THX
[LINK]: Hotfix2 for Step7 5.4 SP1
HF2 for Step7 v5.4 SP1
http://plcforum.uz.ua//ST ... .part1.RAR
http://plcforum.uz.ua//ST ... .part2.RAR
Readme wrote:What has Changed Compared to Version STEP 7 V5.4 SP1?
HW Config
With certain configurations for CPU4xx V5.0 as PN IO controller (clock pulse < 1 ms) and IE/PB links as PN IO devices in V5.4 SP1, sometimes individual DP slaves could not be put into operation downstream from an IE/PB link. This reaction was corrected in Hotfix 2 for V5.4 SP1.
The IM466 functions without restriction in configurations together with CP443-1 Advanced and CP443-5 Extended.
The firmware update in the SIMATIC Manager was improved for the IM151-3 PN.
A discrepancy error (discrepancy time expired) is now also recognized for redundantly installed digital input modules following the failure and return of the master system.
As of STEP 7 V5.4 SP1 Hotfix 2, both CPUs with the order numbers 6ES7 612-2QH10-0AB4 and 6ES7 616-2QL10-0AB4 are CiR capable. Configuration in run (CiR) is described in the help on STEP 7 under "Modifying the system during operation via CiR" or in the manual of the same name. Both CPUs can only be configured and operated in a PC station. If one of the CPUs is used in a PC station in the operating mode CiR, no additional components (application/CP/CPU) can be configured in the PC station.
NCM
The functionality of the CP1616/1604 has been improved.
The SNMP variable export for IPC profiles has been updated.
The system behavior of the CP343-1EX21 (6GK7 343-1EX21-0XE0 V1.1) has been improved.
For OPC, the behavior during "immediate response" has been updated.
The function "Upload" for configurations with DP/AS I-slaves has been improved.
SIMATIC Manager
The behavior of the function "Save As with Reorganization" has been improved.
Report System Error
Hotfix 2 for STEP 7 V5.4 SP1 is prerequisite for the operation of the SIMATIC Maintenance Station.
