[?+]: Crack for Eplan 5.70.3 only for Windows XP
Тools, Elcad, Eplan, ...
dragan
Post by dragan » Mon May 07, 2007 11:36 am
I need crack for EPLAN 5.70.3. I tried all suggestion found on this forum, but it doesn't work. Does any body have some new method?
mlago
Post by mlago » Mon May 07, 2007 2:19 pm
see teh link of last post http://www.plc.net.ru/viewtopic.php?t=6030, it's also work whit the 5.70 versión.
dragan
Post by dragan » Mon May 07, 2007 2:42 pm
Hi malgo.
I already try that crack but doesn't work. I got following meassage:
"This license is not compatible with the program! Please select another license."
Regards,
mlago
Post by mlago » Tue May 08, 2007 7:25 am
Hi dragan. I also have the 5.70.3 version and it work fine. Test to maintain pressed shift while you start eplan, to have to appear a window with the list of licenses available. regards, and excuse for my english.
dragan
Post by dragan » Tue May 08, 2007 8:28 am
Hi mlago.
Thanks for your effort to solve my problem. I would like to share with all of you my experience. Up to now I tried to apply EPLAN_P8_ALL_CRACK.exe on my desktop computer which is run under WIN 2000 and doesn't work. After that I do same on my laptop ( run on WIN XP) it work without any problem.
Thank again,
Regards
Schtiel
Post by Schtiel » Tue May 08, 2007 10:35 am
Hi, dragan!
Probably your WIN2000 is installed in directory "C:\WINNT", that's why that crack doesn't work.
Try to copy file LCLIC32.DLL from directory "C:\WINDOWS" on your laptop with WIN XP to directory "C:\WINNT" on your desktop computer with WIN2000.
Good luck!
