[?]: omron cx-server opc installation problem
CX-One, CX programmer, NTST, Syswin ....
cheucc
Post by cheucc » Sun May 06, 2007 4:46 pm
I got following error and the installation exit while install omron cx server opc at 33 percent:
component: cx-server Graphic components
File Group: Graphical components files(unregistered)
file: c:\program files\common files \omron\components\nederlands
(Belgi?.ind
error:the file name, directory name, or volume label sytax is incorrect
Please help to fix it . I will appreciate your help!
Dr PLC
Re: [?]: omron cx-server opc installation problem
Post by Dr PLC » Tue Mar 07, 2023 2:29 am
First, make sure you install from a local copy under a directory path to which the current user has full access permission. Also, check the installation guide's perquisites or requirements, including the .NET framework, windows version, and bit size. Please do not hesitate to share more information and feedback at any time to give you support as we can.
