There is a link on this site to download MS SQL2005 for WinCC 6.2 .
I downloaded this software twice but when installing at a certain moment the installation programm tells that some files are corrupt.
Is there anyone else who can put this software online?
[?]: Can't install MS SQL2005 for WinCC 6.2
Hello.
I can't install MSSQL 2005.
I have 2 versions: 1st was downloaded from this portal and other 1 I've got.
But I have the same following errors:
*I use Symantec Antivirus and Kaspersky KAV.
Could U help me with this problem?
Decision:
Close any Antivirus before to Install MSSQL.
After turn off Symantec Antivirus I have installed MSSQL without problems.
Decision:
in Russian wrote: на одном компе установлен symantec antivirus. На другом стоит KAV.
Вобщем я отключил NAV полностью и потом попробывал установить заново.
На этот раз все прошло гладко.
А вот на другой машине с KAV попробую вечером.
