[FAQ]: How unpack archive and CD-image (ISO, NRG) files
O форуме и файлообменниках.
Правила (или почему могут забанить)
Info
Faq & Info
Faq & Info
Post by Info »
http://plcforum.uz.ua//To ... 0_Plus.zip
Unpack by TotalCommander Plus (with plugins) - big files >2 GB only to NTFS file system disk
also you can unpack ISO, BIN, NRG image file to hard disk [ big files >2 GB only to NTFS file system disk (not FAT32)]
or with WinRAR
CoMod in Russian wrote:Многотомные архивы и образы дисков ISO, BIN, NRG можешь распаковать ТоталКомандиром Плюс, имеющим дополнительные примочки для этого или WinRAR-ом
Select file and press button Unpack or from Files>Unpack files (Alt+F9)
You also can use NERO Burning ROM for unpack and write CD from CD-image files.
Verify Checksums
Copy the file Checksums.MD5 to folder with dowloaded files.
TotalCommander
select file.md5
Files > Verify Checksums
if press CTRL+ENTER in selected file then it opened how folder.
You can select files and folders and press F5 to copy selected files to hard disk
You can use Sateria when press this button
when unpack RAR files
--------- How unpack parts with extentions 001,002,...00N ---------------
merge with total commander menu File > Combine
in Russian wrote:Склеивать Тотал Командиром меню Файл > Склеить
Verify SFV/MD5 checksums
verdis wrote:how do you open a .sfv file?
SFV is text file with checksums
TotalCommander:
Press F3 for view
Menu File>Verify SFV checksums...
Copy the Checksums.md5 to folder with dowloaded files.
TotalCommander
select file.md5
Info
Faq & Info
Faq & Info
Total Commander 7.00 final with key
Post by Info »
http://www.ghisler.com/
http://plcforum.uz.ua//To ... th_key.zip
For pack/unpack I use Total Commander with plugins
http://plc.net.ru/viewtopic.php?t=6036
You can pack with options "Multiple disk archives"
or
File > Split big archive to small parts
vayghan
make ISO image of CD/DVD
Post by vayghan »
Dears,
would you please introduce a software to make ISO image from CD/DVD? as i checked by some of them (nero,clone cd) ,its impossible to make ISO image by these softwares directly from cd/dvd.
regards
E.Hashemipour
Link
Forum Community
Forum Community
Post by Link »
Total Commander v7.50a with key.zip
http://plcforum.uz.ua//T ... 0a_key.zip
or
http://narod.ru/disk/13586143000/TotalC ... y.zip.html
http://plcforum.uz.ua//TotalCommander_v7.50a_key.zip
or
http://narod.ru/disk/13586143000/TotalCommander_v7.50a_key.zip.html
