[LINK]: I/O server for intouch 9.5
PLC_ITA
Post by PLC_ITA » Mon Apr 23, 2007 7:19 pm
Hi friends, any one have a I/O server for intouch 9.5 .
I need to connect with a S7 300 via ethernet
Thank a lot
PLC_ITA
Post by PLC_ITA » Tue Apr 24, 2007 3:48 pm
Thank you Little_Cat
PLC_ITA
Post by PLC_ITA » Wed Apr 25, 2007 4:26 pm
Hello Little_cat, i'm already here. I'm new, in Intouch world, or better I have already work 7 years ago whith release 7.0 .
Now i need to connect with s7 300 via ethernet and cp341.
I remember that in the I/O server 3964r ( for serial communication ) put the access name ( topic ) an the communication port, an then in Intouch, in the tagname dictionary there is the access name,
In The DAserver i have read the help but i dont understand which parameter are necessary to specify.
I have try to put tcp/ip address, slot ecc, but in Intouch i dont foind the access name
Can you help me ?
Thank you
votuandktd
Post by votuandktd » Wed Apr 25, 2007 5:06 pm
Many thank!
Roman
Connect S300 to InTouch
Post by Roman » Wed May 02, 2007 9:38 am
Visit www.wonderware.com and download from there technodes explained
how connect s300 to intouch. Or write yours mail address and I send this technodes for you.
nhanttri
Post by nhanttri » Tue May 08, 2007 7:27 am
i looking for io server for mitsubishi Q series
anybody help?
nautical
Post by nautical » Sat May 12, 2007 1:28 pm
Thousand THZ!!!
I will test it with my IT9.5 and BTW, I am going to use the Top Server or Kepware for OPC server. Is anyone can provide me those licences!!!!
Contact:
Post by sania » Sun Jul 29, 2007 5:42 am
nautical wrote:Thousand THZ!!!
stop not sense post :!: :!: i`ll ban you if not stop :!:
i deleted several your post
see http://plc.net.ru/viewtopic.php?t=6031
