[?+]: WinCC Flexible demo to full
pacheco
Post by pacheco »
hello !
Can I convert the WinCC Flexible demo version to version full ??
If it's possible how can i do that???
thanks 8) :twisted:
Try to install keys for WinCC Flexible
http://plc.net.ru/viewtopic.php?p=10252#10252
http://www.automation.siemens.com/infoc ... y=&lang=en
WinCC flexible 2005 SP1 - Trial CD wrote:SIMATIC WinCC flexible can be used as a Trial Version for 30 days.
Use beyond this period is only permitted when a licensed WinCC flexible installation has been properly loaded on the PC.
After the thirty day period has expired, you can no longer start WinCC flexible.
If keys will not help, means it is necessary to download the normal version from http://plc.net.ru/viewtopic.php?t=92
Russian wrote:Попробуй установить ключи для WinCC Flexible
Если ключи не помогут, значит надо добывать нормальную версию
pacheco
Thank's
Post by pacheco »
Hello!!!!! the software is working normally
Good !!!!!!!!!!!!! :lol: :D
