[?]: how can i introduce input and output via SCL
Sabicas
Post by Sabicas » Tue Feb 20, 2007 9:04 am
how can i introduce input and output via the SCL
OMU
Post by OMU » Tue Feb 27, 2007 3:36 pm
You can use them directly in your source
Example:
If  I6.2 then Q2.2
End_if
If you wish to create an FB or FC with in- and outputs, then you have to
define them as variables, example:
VAR_INPUT
FAST_B      :  INT;  // (can also be bool, dint etc.)
SLOW_B     :  INT;
STEP_B      :  INT;
END_VAR
I hope, this will answer your question.
C U
Uli
