Hey guys, i need your help.
I need to know the algorytm to calculate in continuos mode
a diameter of the Aspo in a paper machine
I have a speed of the machine and know ( via encoder on the motor )
the speed of motor at the end of this machine. To regulate the speed i need to calculate in continuos the diameter that increase during the
work
in this machine i put a Siemens PLC, but for select a type of CPU, before
i need to know this system of algoritm
Can you help me ?
Do you know where i can found documentation ?
[?]: Algorytm to calculate diameter in Aspo
PLC_ITA
graf_STEP7
I think it is Easy.Can you help me ?
1. Check the speed. U/min.
2. Reset the "round-Counter"
3. Count how often the roll ist turn
4. Wait (1 minute)
5. Check now how often the roll ist turnung after reset.
Now you can calculate how big is the papper.
Now Calculate the fix-roll-diameter .
When you now know how many layer is on roll
--> (min-paper + act-paper) / 2 --> middle of diameter.
You know how many paper is on 1 layer --> Calulate it (aktual length)
I think, it give no Documentation for this problem.Do you know where i can found documentation ?
P.S. I have an P.M.
You are an Costumer ?
You works for Agnati ?
graf_STEP7
ciwa
Siemens have this application manual for center winder using simoreg, try this manual
http://support.automation.siemens.com/W ... 4=20208582
company66
Hello
I used ABB drive 800 Winder Unwinder it works perfectly
you need to give the drive the speed line, the torque in %, and another parametre called Tapper in %.
the software that calculate the diameter is preinstalled on the drive by ABB. but first you must contact your nearest ABB dealer he will give you the good drive for your aplication.
I hope i was clear.
I hope i was clear.
PLC_ITA
koinahi
use rockwell Drive Application Software. you will find it on
http://www.ab.com/drives/drvappsw/pf700 ... dules.html.
(drivelogix is just like control logix you can open that with rslogix5000)
