[?]: How to crack SIEMENS 6RA70 S00 code
How to crack SIEMENS 6RA70 S00 code?
Any one have tools to crack that?
Re: [?]: How to crack SIEMENS 6RA70 S00 code
Maybe this software Technology software in the basic unit 6RX1700-0AS00 may enable the S00 software.
Anyone who have this one please upload!!!
i can enable S00
By read eeprom
edit parameter to 2000 hr
i can see password too
By read eeprom
How do I place this reading, I have to take the eprom or is otherwise ?
Details, read eprom to see the link http://www.LancOS.com.
See No. spi eeprom 25128.
Needs to build special cable and just to connect to the drive or not. Please clarify connection way.
Best regards
Best regards
Public Class Form1
Const h000_0 As UShort = 0
Const h000_1 As UShort = 0
Const h500_0 As UShort = 30528
Const h500_1 As UShort = 27
Const h150_0 As UShort = 26053
Const h150_1 As UShort = 82
Const h200_0 As UShort = 56576 'dd00
Const h200_1 As UShort = 109 '006d
Dim ADD_3FE0 As UShort
Dim ADD_3FF4 As UShort
Dim ADD_3FF6 As UShort
Dim ADD_3FFA As UShort
Dim point_add As UShort
Dim buffer As UShort = 0
Private Sub RadioButton1_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton1.CheckedChanged
ADD_3FF4 = h000_0
ADD_3FF6 = h000_1
End Sub
Private Sub RadioButton2_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton2.CheckedChanged
ADD_3FF4 = h500_0
ADD_3FF6 = h500_1
End Sub
Private Sub RadioButton3_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton3.CheckedChanged
ADD_3FF4 = h150_0
ADD_3FF6 = h150_1
End Sub
Private Sub RadioButton4_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton4.CheckedChanged
ADD_3FF4 = h200_0
ADD_3FF6 = h200_1
End Sub
Dim sum_check As UInt32 = 0
ADD_3FF4 = h000_0
ADD_3FF6 = h000_1
End Sub
ADD_3FF4 = h500_0
ADD_3FF6 = h500_1
End Sub
ADD_3FF4 = h150_0
ADD_3FF6 = h150_1
End Sub
ADD_3FF4 = h200_0
ADD_3FF6 = h200_1
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ButRead.Click
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ButWrite.Click
Dim FileName_resorce As String
Dim FileName As Integer = FreeFile()
Dim FileLenght As Integer
sum_check = 0
' กำหนดเงื่อนไข ว่าต้องเลือกไฟล์ก่อน read ถ้าไม่ใส่ให้ออกจาก if
If TextBox5.Text = "" Then
MsgBox(" กรุณาเลือกไฟล์ที่ต้องการ Read โดยกด Browse ก่อน ")
Else
FileName_resorce = TextBox5.Text
FileOpen(FileName, FileName_resorce, OpenMode.Input, OpenAccess.Read, OpenShare.Shared)
FileLenght = FileLen(FileName_resorce)
FileClose(FileName)
If FileLenght = 16384 Then
Dim br As BinaryReader = New BinaryReader(New FileStream(FileName_resorce, FileMode.Open))
For point_add = 0 To 8191 ' ISP 25128
buffer = br.ReadUInt16()
If point_add = 1851 Then
TextLock0.Text = buffer
End If
If point_add = 1852 Then
TextLock1.Text = buffer
End If
If (8177 <= point_add) And (point_add <= 8185) Then
sum_check = buffer + sum_check
End If
If point_add = 8186 Then
ADD_3FF4 = buffer
End If
If point_add = 8187 Then
ADD_3FF6 = buffer
End If
If point_add = 8188 Then
End If
If point_add = 8189 Then
ADD_3FFA = buffer
End If
If (8190 <= point_add) And (point_add <= 8191) Then
' MsgBox(sum_check)
End If
Next
Select Case ADD_3FF4
Case h200_0
If ADD_3FF6 = h200_1 Then RadioButton4.Checked = True Else RadioButton1.Checked = True
Case h150_0
If ADD_3FF6 = h150_1 Then RadioButton3.Checked = True Else RadioButton1.Checked = True
Case h500_0
If ADD_3FF6 = h500_1 Then RadioButton2.Checked = True Else RadioButton1.Checked = True
Case Else
End Select
TextBox3.Text = ADD_3FFA
ButWrite.Enabled = True
MsgBox(" Read ok ")
br.Close()
' ให้จบเงื่อนไขของ if อันแรก กรณีที่ไม่ระบุชื่อไฟล์
Else
MsgBox("This File is Incorrect")
End If
End If
End Sub
Dim FileName_resorce, FileName_output As String
MsgBox(" กรุณาเลือกไฟล์ที่ต้องการอ่านในช่อง Search & สร้างชื่อไฟล์ในช่อง Create แล้วกดปุ่ม Read ก่อน")
ElseIf TextBox6.Text = "" Then
MsgBox(" กรุณาใส่ชื่อไฟล์ ที่ต้องการเก็บผล ที่ช่อง Create File Name")
Else
FileName_output = TextBox6.Text
Dim bw As BinaryWriter = New BinaryWriter(New FileStream(FileName_output, FileMode.Create))
If CheckBox1.Checked Then
ADD_3FFA = 0
End If
ADD_3FE0 = ADD_3FF4 + ADD_3FF6 + ADD_3FFA + sum_check
If point_add = 8176 Then
bw.Write(ADD_3FE0)
bw.Seek(16354, SeekOrigin.Begin)
ElseIf point_add = 8186 Then
bw.Write(ADD_3FF4)
bw.Seek(16374, SeekOrigin.Begin)
ElseIf point_add = 8187 Then
bw.Write(ADD_3FF6)
bw.Seek(16376, SeekOrigin.Begin)
ElseIf point_add = 8189 Then
bw.Write(ADD_3FFA)
bw.Seek(16380, SeekOrigin.Begin)
Else
bw.Write(buffer)
End If
Next
bw.Flush()
ButWrite.Enabled = False
MsgBox("write complet ")
br.Close()
bw.Close()
sum_check = 0
ADD_3FE0 = 0
ADD_3FF4 = 0
ADD_3FF6 = 0
ADD_3FFA = 0
End If
End Sub
