![Link Dead [dead]](./images/smilies/Link_dead.gif)
WinAC v4.1 Demonstration CD
9 * 44.444.444 + 18.808.290
This Setup is only for the following products:
SIMATIC NET CD 11/2003
None of these products is installed on your computer.
Setup will be aborted...
Simatic NET for this WinAC in the folder SN62_HF04 (V6.2.4)Readme wrote:3 Software Requirements
WinAC Basis V4.1 SP1 requires either of the following operating systems:
Microsoft Windows 2000 Professional, Service Pack 3 or higher
Microsoft Windows XP Professional, Service Pack 1
Note: SIMATIC NET V6.2.1 does not support Service Pack 2 for Windows XP. Do not upgrade your computer to Windows XP SP2.
Before you install WinAC Basis, you must first install the appropriate SIMATIC NET software:
SIMATIC NET V6.2.1 or later
The SIMATIC NET CDs are supplied as part of the WinAC Basis package.
Note
WinAC uses functionality of the SIMATIC NET software that does not require an authorization. If you do not plan to use any SIMATIC NET product, deselect the option for running the automatic authorization when you install the SIMATIC NET software for WinAC.
* SIMATIC NET CD 11/03 HF4 *
Date: 04/14/2004
This file contains the latest information about the product:
- Avoid a message box of the CI_DLL.DLL that prevents correct startup of
WinAC.
