Colleagues,
As from WinCC V6.0+SP3 an additional license for Softnet S7 Lean is also supplied to stablish a TCP-IP communication. This therefore licenses SIMATIC NET for 8 connections.
I have installed Simatic Net CD for PC 2005 provided with Wincc V6.0 SP4 Package but i only can see the Configuration Console to configure CP and Access Points.
I can´t find Sofnet S7 Lean Software and license inside to the WinCC V6.0 SP4 Package?
I am trying to stablish TCP-IP communication with a CP 1612 and it is not possible.
What additional software or license i need to do it!
Thanks for your help.
Juan M.
[?]: WinCC V6.0 SP4 and TCP-IP S7 Communication
Install Simatic Net 2006
http://plc.net.ru/viewtopic.php?t=5184
SIFLNIERCN0604 NET Industrial Ethernet S7-REDCONNECT
SIFLNHIES70604 NET Industrial Ethernet S7-1613
SIFLNHPBDP0604 NET PROFIBUS DP-5613
SIFLNHPBFM0604 NET IPROFIBUS FMS-5613
SIFLNHPBS70604 NET PROFIBUS S7-5613
SIFLNOPCCB0604 NET Industrial Ethernet PN CBA OPC-Server
SIFLNOPCDX0604 NET DX OPC-Server v6.4
SIFLNOPCSB0604 NET SNMP-OPC-Server Basic
SIFLNOPCSE0604 NET SNMP-OPC-Server Power Pack
SIFLNSIEPG0604 NET Industrial Ethernet SOFTNET-S7 Basis
SIFLNSIEPN0604 NET Industrial Ethernet SOFTNET PN IO
SIFLNSIESE0604 NET Industrial Ethernet SOFTNET-S7 Power Pack
SIFLNSIESL0604 NET Industrial Ethernet SOFTNET-S7 Lean
SIFLNSPBDP0604 NET PROFIBUS SOFTNET-DP
SIFLNSPBDS0604 NET PROFIBUS SOFTNET-DP Slave
SIFLNSPBS70604 NET PROFIBUS SOFTNET-S7
