Request: Trend Viewer v.3.0
maverik53
Post by maverik53 » Thu Jan 04, 2007 6:23 pm
We need Licence for Trend Viewer v 3.0 from ICSGMBH
Tank You
You find the demo version here.
http://www.icsgmbh.de/english/GdcXyeR.htm
ppp
Post by ppp » Fri Jan 05, 2007 10:41 am
In due time studied this product. It is too much opportunities at it it has been declared on display of schedules.
And other products of this firm are executed quite professionally and unique.
But this has not liked me TrendViewer.
The product with adjustments in the form of ActiveX is necessary to me.
Built in in wincc a viewer as it has appeared to use a hundred times more conveniently (though and a little there adjustments)
The majority of adjustments in TrendViewer is possible only commands in the form of functions C.
Without server TrdDBServer (from the same firm) it will not work. And one license will not rescue you.
At the manufacturer has elicited (from the tenth attempt) the project for WinCC v5.0, its complexity has not liked.
One access to data through ODBC that costs on complexity.
At me in all average project for that moment was as much scripts, how many they used for display of 5 tags (16 pieces total amount 32кБ)
All is not evident and with mistakes at work.
In my opinion it is easier activeX to write than repeat the something similar.
All aforesaid concerns to TrendViewer v2.
The third version did not look, but I do not think that essentially have changed something.
On official site TrendViewer now it is not specified even not, that it can be used with WinCC (was earlier)
In my advice - hammer on this product. It was written initially not for WinCC, and for developers as environment, therefore in WinCC so uneasy and to use it...
Russian wrote:В свое время изучал этот продукт. Уж больно много возможностей у него заявлено было по отображению трэндов. Да и другие продукты этой фирмы выполнены вполне профессионально и единственные в своем роде.
Но не понравился мне этот TrendViewer.
Мне (как и большинству винсисишных писателей) нужен продукт с настройками в виде ActiveX.
Встроеный в wincc вьювер как оказалось использовать в сто раз удобнее (хотя и маловато там настроек)
Большинство настроек в TrendViewer возможно только командами в виде сишных функций.
Без сервера TrdDBServer (от той-же фирмы) он работать не будет. И одна лицензия вас не спасет.
У производителя выцыганил (с десятой попытки) проект для WinCC v5.0 (там на сайте есть мыло автора), так ужаснулся его сложности.
Один доступ к данным через ODBC чего стоит по сложности.
У меня во всем среднем проекте на тот момент было столько же скриптов, сколько они использовали для отображения 5 тэгов (16 шт общий объем 32кБ)
Все не наглядно и глючно.
По-моему легче свой activeX написать чем повторить что-то подобное.
Все вышесказанное относится к TrendViewer v2.
Третью версию не смотрел, но не думаю что принципиально что-то изменили.
На официальном сайте TrendViewer сейчас даже не указано, что его можно использовать с WinCC (раньше было)
Мой совет - забейте на этот продукт. Писался он изначально не для WinCC, а для разработчиков как среда, поэтому в WinCC так непросто и использовать его...
maverik53
Post by maverik53 » Wed Jan 10, 2007 9:03 am
PPP can you write in english please?
Tank You
maverik53
Post by maverik53 » Mon Mar 12, 2007 9:51 am
Any news?
aerogard
Post by aerogard » Mon Nov 12, 2007 3:00 pm
maverik53 wrote:Any news?
Well, this was posted _only_ in March :)
Anyways, I made these licences for someone (both Trendviewer and Analyser) on a very boring, rainy day. Some folks may utilize them.
D/load:
*http://mihd.net/yfu1e0
then put them into their respective directories.
Cheers
votuandktd
Post by votuandktd » Fri Nov 30, 2007 5:02 am
D/load:
Cheers
I need licence for PicCAD. Anyone have, please upload.
Many thanks,
maverik53
Post by maverik53 » Sat Mar 01, 2008 11:00 am
Developer license here
Link_is_Dead :(/trv30devr.rar
