[INFO]: WinCC V6.2
[INFO]: WinCC V6.2
WinCC V6.2See link to files http://plc.net.ru/viewtopic.php?t=5705
http://www.automation.siemens.com/hmi/h ... erview.htm
http://www.automation.siemens.com/hmi/h ... ptions.htm
http://support.automation.siemens.com/W ... e/24368350
Overview
The new version 6.2 of the scalable process visualization system SIMATIC WinCC offers new features for the standard visualization as well as for the optimization of the production through Plant Intelligence. Innovations to existing WinCC options and new options further expand the functionality of the overall system:
Effective immediately, Windows elements such as menus and toolbars can be integrated into the user interface of the runtime application.
The alarm system receives the function “Alarm Hiding”. By selectively hiding alarms at times when there is a large number of messages provides greater clarity, specifically for the use in larger plants.
At the same time the current database Software Microsoft SQL Server 2005 was integrated. Thus a central archive server can now also be – optionally – set up for the central process data archiving with a maximum of 120 000 archive tags.
In doing so, a Windows computer can – if desired – be set up as a connectivity station with access to all current and historical WinCC data in the database.
Furthermore, a SIMATIC WinCC station, in addition to its task as process visualization and operator station, can now also be configured as a SIMATIC Maintenance Station for efficiently maintaining a plant.
Innovations to the WinCC basic system:
Runtime-user interface with Windows Look & Feel
Expanded alarm system
Integrated Microsoft SQL Server 2005
Operation with firewall and virus scanners
Innovations to the WinCC options
WinCC Redundancy V6.2 now also with synchronization of the alarm system and internal tags
WinCC/Connectivity Pack V6.2 with simplified access to distributed systems and redundant configurations
WinCC/Web Navigator V6.2 enables access to the plant-wide central user administration and offers the use of global C variables at the Web client http://support.automation.siemens.com/W ... e/24369567
WinCC/Audit V6.2 now also with an integrated project versioning tool
WinCC/Server V6.2
WinCC/User Archives V6.2
WinCC/IndustrialX V6.2
WinCC/Client Access License
WinCC/Client Access License pro Prozessor
WinCC/ODK V6.0 SP4
SIMATIC Logon V1.4
WinCC/IndustriaDataBridge V6.1 (Verträglichkeit mit WinCC V6.2)
New WinCC Options:
WinCC/Central Archive Server WinCC/CAS V6.2 - for a central process data archiving f
WinCC/Connectivity Station V6.2 - for easy data access in distributed systems
WinCC/ChangeControl- for tracking and tracing changes made to the configuration
SIMATIC Maintenance Station for efficient plant maintenance
