[?]: I want to install WINCC Flexible 2005 on Windows 2003
j0rdan
Post by j0rdan » Tue Dec 12, 2006 6:49 am
I have windows 2003 and i want to install wincc flexible 2005 on it.
But it isn't possible to do it under windows 2003.
Is anyone know a way to do this because i really don't want to work under XP?
bunglehead
Post by bunglehead » Tue Dec 12, 2006 8:24 am
Can you describe your problem?
When does install program stop? With what error messages?
What version of .NET Framework do you use?
j0rdan
Post by j0rdan » Tue Dec 12, 2006 9:04 am
When i start instaling wincc flexible 2005 under windows 2003 it stops on the beginning with error please install wincc flexible 2005 under windows 2000 sp4 or windows xp sp2.
My pc is with windows 2003 system.
I trie it with .net framework version 2.0 and with .net framework version 1.1
rataman
Post by rataman » Tue Dec 12, 2006 3:07 pm
You must edit the setups.ini file in the root directory, just besides setup.exe, search for the [OS] section and edit
WinNETServer=False to WinNETServer=True
and add the line WinNETServerExclude=0
It worked for me, but you must try and see.
j0rdan
Post by j0rdan » Wed Dec 13, 2006 6:48 am
rataman wrote:You must edit the setups.ini file in the root directory, just besides setup.exe, search for the [OS] section and edit
Thank you rataman i'll try it know it can help me very much.
