[LINK]: iFix Crack
Re: I just download iFIX crack...............
Install iFix3.5 License keyapsins wrote:How to crack?
1) Copy flie license.sys to folder %SystemRoot%\intellution\,
when %SystemRoot% is "c:\Windows" for Widdows XP and "c:\Winnt"
for Window 2000.
2) Run file key.reg (Else need edit key.reg for your Windows).
3) Install license-unility from CD-ROM (path CD-ROM:\license\setup.exe)
Help please.. (Sorry for bumping old thread)
Hi,.. really sorry for bumping this old thread..
I need help in inctalling the 1Fix 3.5 license key..
I download the Intellution software from emule.
The file name is Intellution.iFix.3.5.J@V@Power.2K4.ISO.
After that, i download the crack from http://www.oxedion.de/index.php/downloa ... b548d8beb8
Since reg file is not for Win XP, I change it to
(refer to http://www.plc.net.ru/viewtopic.php?t=5 ... light=ifix)
After that, I put the licence.sys in folder windows\intellution.
Then I double click on the reg file and finally install the license utility..
But after everything, the iFix still run as demo..
I don't have any HW key or anyhing like that.. Please help..
Thanks..
[HKEY_CLASSES_ROOT\.iekey]
"license"="C:\\Windows\\Intellution\\slapi.dll"
"license_file"="C:\\windows\\intellution\\license.SYS"
"license_id"=dword:00000
Thanks..
My Ifix OK ...
But how to change date to 01/01/2253 or 01-01-2253
I use the link from here, but not installed Fix Desktop...
http://www.plc.net.ru/viewtopic.php?t=5861&start=0
Galli,
Where did you get the iFix software from..?
is it from emule..?
If ur file Intellution.iFix.3.5.J@V@Power.2K4.ISO..?
As for the crack, i went to ftp://ftp.indusoft.ru/GEFanuc_Products/ but there are so many files there.. which is the license file..?
is it from emule..?
First, I use Fix3.5_with_FixDesktop from indusoft_ru ftp site ...
Now no more in the ftp site ..
Second, I use Fix3.5 from here when the first one problem to install ...
http://www.plc.net.ru/viewtopic.php?t=5892 --> rapidshare..
Then OK ..
Then OK ..
Ok Help is here Galli!
1. Download the CD Image from RapidShare Links below:
Link_is_Dead :(/ifix3_5.part1.rar
Link_is_Dead :(/ifix3_5.part2.rar
Link_is_Dead :(/ifix3_5.part3.rar
Link_is_Dead :(/ifix3_5.part4.rar
Link_is_Dead :(/ifix3_5.part5.rar
2. Download the crack from:
3. From CD or Image reader (like Alcohal120%) install IFix 3.5
4. After installation completes copy XP licence or 2K licence to
c:\Windows\intellution\ --- (For XP normally)
or
c:\Winnt\intellution\ --- (For Win 2K normally)
5. Right Click the 'key.reg' file and select merge
6. This is important: Run the setup.exe file from CD directory i.e.
\license\setup.exe
7. Restart the system
8. Double Click the 'Intellution iFIX 3.5' icon on the desktop (You will get the Dialog You have been waiting for !!!).
9. Dont Change anything and just click the Button 'Create a shortcut on your desktop .......' i.e the one at the bottom.
10. Press Exit button
11. Double click the newly created icon (With the name of your User account)
BINGO! You are up and running in the Workspace.
Hope it helps!!!
Cheers!!!!
or
\license\setup.exe
Hope it helps!!!
Cheers!!!!
Broken Link
This link to the crack does not work. Do not give to spend another?
Re: Broken Link
See in topic http://www.plc.net.ru/viewtopic.php?p=14291#14291Rogertecn wrote:This link to the crack does not work. Do not give to spend another?
zenchek
