Problems running WinCC V6.0 SP4 and license missing
Mendicoaj
Post by Mendicoaj »
Hello colleagues,
I have installed WinCC 6.0 SP4 and SQl Server SP4 but i am having problems with the keys.
Could anyone tell me how to proceed to crack it and where download the keys?
----- 08/11/2006 --------
I just have installed WinCC V6.0 SP4 and when i try to create a new project i receive and error message of
Error Message wrote:"0x80070035: The network path was not found".
I am using patch default folder of WinCCProjects in C:ProgramFiles/Siemens/WinCC/WinCCProjects.
Additionally, i only find my WinCC as Demo after install all my keys.
What should i try to do to my WinCC V6.0 SP4 works good!?
Thanks.
http://simatic.net.ru/viewtopic.php?t=218
You can install short keys by Siemens.exe or Normal Long keys from Yellow Flash.
Keys from WinCC RunTime floppy disk for RT WorkStation
SISLA9WRT40600.ekb WinCC RT (65K) - Runtime only with 65536 Tags
SISLA9WC250600.ekb WinCC SIMATIC 505 TCP/IP
SISLA9WCL60600.ekb WinCC Profibus FMS
SISLA9WC190600.ekb WinCC TI Ethernet Layer4
SISLA9WC180600.ekb WinCC S5 Ethernet Layer4
SISLA9WC170600.ekb WinCC S5 Ethernet TF
A9SNEL90.ekb SIMATIC NET IE SOFTNET-S7 Lean
Keys for WinCC RC (RunTime and Configuration)
SIFLA9WRC40600.ekb WinCC RC (65536) - Runtime+Configuration with 65536 Tags
SISLA1WPC20600.ekb WinCC Advanced Process Ctrl
SISLA1WPC40600.ekb WinCC Chipcard
SISLA9WARC0600.ekb WinCC User Archives
SISLA9WOP10601.ekb WinCC Connectivity Pack
SISLA9WSEC0600.ekb WinCC Server
SISLA9WSN10601.ekb WinCC WebNavigator (3)
SISLA9WSRD0600.ekb WinCC Redundancy
SIFLA0SHLA0601.ekb S7-REDCONNECT
SIFLA0SNEM0601.ekb BCE
SIFLA0SNMX0601.ekb SNMP OPC-Server Extended
See LOG files in C:\Program Files\SIEMENS\WINCC\Diagnose
Mendicoaj wrote: Additionally, i only find my WinCC as Demo after install all my keys.
This is not good.
What ALM version you use?
What type and name of keyfiles?
How install keys?
