[?+]: How to copy password protect program from CPU224
Hi, Any one have a idea or system to upload the program from S7200 Cpu224 whit password protect ?
I need only a safety copy,
Re: Request : How to copy password protect program from CPU2
68 1B 1B 68 02 00 6C 32 01 00 00 00 00 00 0E 00 00 04 01 12 0A 10 02 00 08 00 00 03 00 05 E0 D2 16
10 02 00 5C 5E 16
---------------------zzz-zzz-----------------
IN THE WINDOW OF THE PASSWORD , CAN BE INSERTED ONLY 8 CHARACTERS.
DO YOU SPEAK LANGUAGE HEX ONLY ?
10 02 00 5C 5E 16
Unlock S7-200 - smsasg
Has laid out on http://files.cvalka.net/index.php program S7-Unlock for calculation of the password of any level established on S7-200.
For this purpose it is necessary to have binary image EEPROM AT24C64.
It is checked up on CPU-222 (the image is applied). Who has an opportunity, send similar files from other types CPU for the further operating time.
One of variants of reading of an image *.bin:
1. Establish program PoniProg (www.lancos.com)
2. On the basis of a LPT-socket create a the scheme
3. It is possible to solder a cable to a chip
PLC power off - you can use +5V from USB
4. To consider an image
All it is checked up and efficient...
Images from three types CPU Are applied.
I have a s7-200 CPU224XP and of course I need a password too.....
So guys, what does this s7-200.exe file?? Does it run with the standard PPI/PC programming-cable, or do I need to built this "easyI2Cbus" LPT-connector?
Or has somebody already the password for a s7-200 CPU224XP ??
That would be great
Thanks for let me know guys !!
bye
That would be great
bye
