Release: February 2006
The S7 F Systems V5.2 SP4 contains the following components.
· S7 F Systems V5.2 SP4
· S7 F Systems F-Lib (V1_2) V1.2 SP4
· S7 F Systems HMI V5.2 SP3
· S7 F Configuration Pack V5.2 SP3 and V5.4 SP1
· Add-on for S7 F Configuration Pack V 5.4 SP1 for connection of the F-PA field devices
You need the following components in order to work with S7 F Systems V5.2 SP2 (and higher):
· STEP 7 V5.1 SP5 or higher
· S7 H Systems V5.1 or higher (integrated in STEP 7 V5.3 and higher)
· CFC V5.2 SP1 HF7 or higher
· SCL V5.1 SP5 HF1 or higher
· WinCC V5.1 SP1 HF1 or higher; recommended: V6.0 SP2 or higher (for S7 F Systems HMI only)
Is possible to use only with step 7 V5.4 whit cfc !!
link
![Link Dead [dead]](./images/smilies/Link_dead.gif)
KEY_A1FSYS05.ZIP.html
good work
