[LINK]: Industrial DataBridge 6.1 and keys
This old version http://plc.net.ru/viewtopic.php?p=7569#7569
WinCC Industrial Data Bridge v6.1 and ConnectivityPack v6.1 for WinCC v6.0 SP3
4 * 30 mb + 12.9 mb
[dead] :/127866696/I ... .part1.rar
[dead] :/127867220/I ... .part2.rar
[dead] :/127867270/I ... .part3.rar
[dead] :/127867003/I ... .part4.rar
[dead] :/127866067/I ... .part5.rar
Russian hoster
http://ifolder.ru/7254710
http://ifolder.ru/7254741
http://ifolder.ru/7254777
http://ifolder.ru/7254805
http://ifolder.ru/7254838
5 files
The WinCC/IndustrialDataBridge is a WinCC Option, which can also work as an independent software without WinCC. It allows data exchange between different systems by using standards. Therefore only a simple configuration is necessary and no extra programming is needed. All you need is at least one module as data source and one module as data target. By using a modulare structure the IndustrialDataBridge can be extended with additional data interfaces any time. The design allows the software to integrate easily new interfaces via Plug-Ins. By using the IndustrialDataBridge data between automation systems of different manufactureres can be exchanged e.g. via OPC or Send / Receive. A further possible field of application is the storage of process data in Office formats like Excel and Access. To archive larger amounts of data databases (SQL, Oracle) can be integrated.
The configuration program represents an efficient program helping you constructing the configuration files in the required XML-format. The configuration of the IndustrialDataBridge is carried out with a comfortable user interface. For this purpose you are led step by step through the configuration. To create the tag connection you can also use a CSV file import and export. Thus the effort to configure large numbers of tag connections can be simplified.
In the runtime program you can find means to help you with start-up, status supervision and error analysis. The runtime program permits the access on process data and interlinks the data as it is specified in the loaded configuration file.
The IndustrialDataBridge contains the configuration and runtime environment as well as the following provider and consumer:
Provider (Data source)
OPC Data Access V2
Send / Receive
WinAC Send / Receive
Database (Oracle 9i, MS Access und MS SQL Server)
dynamic Database (Oracle 9i, MS Access und MS SQL Server)
WinCC OLE DB
WinCC Userarchive
Consumer (Data target)
OPC Data Access V2
OPC Data Access Server (internal)
Send /Receive
dynamic Database (Oracle 9i, MS Access und MS SQL Server) for insert and update
Microsoft Excel
WinCC Userarchive
jitomit
Re: [LINK]: Industrial DataBridge 6.1 and keys
Post by jitomit »
Dear CoMod,
Please help to re upload. All links are dead, I really need this for testing of our ancient system. Wincc v6.1.
Thanks in advance!
jitomit wrote:Please help to re upload. All links are dead, I really need this for testing of our ancient system.
Wincc v6.1.
Wincc v6.1 not exist in Nature :)
I can't find Industrial DataBridge 6.1 in my comp :(
one 500 GB disk is dead [dead]
jitomit
Post by jitomit »
My typo, thanks for reply, will try to find IDB in my ancient DVD store. Spasibo bolshoie.
