[LINK] : S7 F Systems V5.2 Fail Safe library function block
PLC_ITA
Post by PLC_ITA » Sat Oct 07, 2006 9:05 am
Hi friends, any one have a Fail Safe library function block .
I need to configure a 400 F/FH system and mr Siemens not
supply a little time this package
Very thanks .
Contact:
Post by CoMod » Sat Oct 07, 2006 11:31 am
See http://support.automation.siemens.com/W ... n/15208817
The F-Configuration tool is part of S7-Distributed Safety and S7 F-Systems.
It provides you with the failsafe modules for Step 7 Hardware Config.
In view of the fact that the release of new failsafe modules does not always coincide with new releases of S7-Distributed Safety or S7 F-Systems packages, the individual versions are herewith provided for downloading.
Contact:
Post by CoMod » Sun Oct 08, 2006 8:11 am
http://support.automation.siemens.com/W ... n/23370607
S7-Distributed Safety V5.4 + Service Pack 1
http://support.automation.siemens.com/W ... lusSP1.ZIP 50457 KB
Service Pack 1 for S7-Distributed Safety V5.4 provides the following improvements.
Access protection:
In conjunction with Step 7 V5.4, the password is now also queried for the following actions:
When saving and compiling a hardware configuration (only the safety program is protected
against changes)
When inserting (new) F blocks into the safety program
When renaming, cutting, moving and deleting F blocks from the safety program
When deleting the offline block container
When deleting the folder "S7 Program"
When opening object properties of F blocks
When editing object properties of an F block
A read mode can be activated when querying a password. This allows, for example, F blocks to be opened without having to enter the password for the safety program. It is then not possible to modify the block.
Logbook for the safety program:
The following actions are included in the log
Modification of the hardware configuration in Hardware Config
Saving of an F block in the offline safety program
Modification of the setting in the dialog "Edit F runtime groups"
Generate safety program
Deactivate safety mode
Load safety program
Load changes to the safety program
Compiler checks:
The following additional possibilities have been created.
Output of a warning if no OV bit scan has been programmed for ADD_I-, SUB_I-, MUL_I-, NEG_I- and DIV_I operations
Detection of write accesses to the F I/O from the standard user program
Detection of F block calls in blocks of the standard user program
Possibility of deactivating the updating of reference data (reduces compiler times)
Safety-related I-slave-slave communication to failsafe signal modules in the ET 200M:
In conjunction with IM153-2 (6ES7153-2BA01-0XB0, from firmware V4.0.7)
Software requirements Operating system
Windows 2000 Prof., Windows XP Prof. and Windows 2003 Server
STEP 7 From V5.3 + SP 3
S7-Distributed Safety Authorization diskette S7-Distributed Safety V5.4 See http://plc.net.ru/viewtopic.php?t=218&start=30
PLC_ITA
Post by PLC_ITA » Fri Oct 13, 2006 4:59 pm
tanks CoMod, the distribuited safety V5.4 is only for F system. I need a Library for FH system.
The package is V5.4 an the cfc block library is V1.2 version.
If you have .....
Now i have order from Siemes, but almost 10 days i need to wait to receive the package.
Eh Eh Eh ... ( sigh ) i leave in Italy !!!
-------- SIMATIC S7 F Systems V5.2 SP4 ----------
Release: February 2006
The S7 F Systems V5.2 SP4 contains the following components.
·	S7 F Systems V5.2 SP4
·	S7 F Systems F-Lib (V1_2) V1.2 SP4
·	S7 F Systems HMI V5.2 SP3
·	S7 F Configuration Pack V5.2 SP3 and V5.4 SP1
·	Add-on for S7 F Configuration Pack V 5.4 SP1 for connection of the F-PA field devices
You need the following components in order to work with S7 F Systems V5.2 SP2 (and higher):
·	STEP 7 V5.1 SP5 or higher
·	S7 H Systems V5.1 or higher (integrated in STEP 7 V5.3 and higher)
·	CFC V5.2 SP1 HF7 or higher
·	SCL V5.1 SP5 HF1 or higher
·	WinCC V5.1 SP1 HF1 or higher; recommended: V6.0 SP2 or higher (for S7 F Systems HMI only)
Library for HF system CFC block is now on line without manual
Is possible to use only with step 7 V5.4 whit cfc !!
link
Link_is_Dead :(/hf_s ... y.001.html
Link_is_Dead :(/hf_s ... y.002.html
Link_is_Dead :(/hf_s ... y.003.html
Link_is_Dead :(/hf_s ... y.004.html
Link_is_Dead :(/hf_s ... y.005.html
Link_is_Dead :(/hf_s ... y.006.html
Link_is_Dead :(/hf_s ... y.crc.html
Link_is_Dead :(/KEY_ ... 5.ZIP.html
good work
Contact:
Post by CoMod » Thu Jan 11, 2007 8:51 pm
SIMATIC S7 F ConfigurationPack
http://support.automation.siemens.com/W ... e/15208817
F-Config_V55SP1.zip
