Can somebody help me out please. I installed S7v5.4 Prof and want to use PDIAG.
The only problem is I can't make any new tag.
I started with the PDF file which explains how to use PDIAG.
But when I want to create a Monitoring Definition I'm not able to do so.
Maybe someone knows the solution to this problem.
Thanks for helping me out.
Kind Regards
[Key]: I can't make any new tag in S7-PDIAG
Maxime
Maxime
PDIAG S7v54
I found out why it didn't work out. I had the wrong soft and key.
So I had version 5.4 of PDIAG and a key for version 5.3.
Does anybody has a key for PDIAG version 5.4?
Thanks anyway
Thanks anyway
KeyIMA
Try
http://files.cvalka.net//index.php?acti ... ry=Simatic&
Use EKB_Yellow_Disk.exe for Create floppy.
You can Upload S7-PDIAG v5.4 to RapidShare?
Maxime
Upload PDIAG v5.4
KeyIMA,
PDIAG v5.4 is in S7v5.4, so you don't need to download it separately.
Thx for the key!
Thx for the key!
KeyIMA
The key works?
I thought it the separate program with the expanded opportunities
So was in a package the Step 7.5.3 http://support.automation.siemens.com/W ... n/22014409
S7-Pdiag 5.3 with keys for Step7 >=v5.3.3
http://rapidshare.de/files/5748149/Pdia ... s.zip.html
33 mb
33 mb
Maxime
The Key Works Very Fine
KeyIMA,
The key works very fine indeed!
I think you're right about the separate download and features...
Maxime
Maxime
