[LINK]: STEP 7 V5.4 Prof Service Release 1 (SP1) and key
Juli
Post by Juli » Fri Sep 15, 2006 8:01 pm
Hi
today we have a new version Step7 with SP1.
In SP1 is a new Automation License Manager V3.0
this Manager find cracked
LONG FastCopy license ........dont install because install and remove
or install short keys by Siemens.exe
or install New normal Long keys from YELLOW FLASH (see bottom)
here is the link to SP1
German link:
http://support.automation.siemens.com/W ... &caller=nl
English link:
http://support.automation.siemens.com/W ... n/23849953
http://support.automation.siemens.com/W ... n/22445425
Service Pack 1 for STEP 7 V5.4
http://support.automation.siemens.com/W ... 54_SP1.exe 194 Mb
maverik53
Post by maverik53 » Sat Sep 16, 2006 8:46 am
No problem if you install Short Key (A1710454.ekb or S7prof54.ekb) by Siemens.exe with this file:
Link_is_Dead :(/files/33299907/S7v54.Link_is_Dead :(
Tested on Step7 V5.4 SP1
Juli
Post by Juli » Sat Sep 16, 2006 3:34 pm
thanks for editing my message because so it is better
regards
Juli
TioPepe
Post by TioPepe » Sun Sep 17, 2006 4:33 am
:lol: This utility install LONG FastCopy license and short keys without problem.
Link_is_Dead :(/files/33398288/EKBBackup.exe.html (This old version)
-------Add 2006-09-30 New version Fix this problem --------
see http://plc.net.ru/viewtopic.php?p=6851#6851
EKBBackup v1.0.1.33 2006-09-30
http://files.cvalka.net
EKBBackup 2006-09-29
Link_is_Dead :(/files/34961313/EKB ... _09_29.zip
BadNews
EKBBackup not work with ALM 3
Post by BadNews » Sun Sep 17, 2006 7:55 am
Утверждается, что эта программа нормально устанавливает длинные ключи под ALM 3
.... EKBBackup.exe.html
EKBRename and old EKBBackup (before <v1.0.1.32 2006-09-29) use FastCopy byte for "install" keys.
ALM 3 ignore keys with "FastCopy" byte09=0.
In this example I install 2 keys from original Yellow Disk and other keys install by EKBBackup 2006 07 11.
EKBRename и EKBBackup используют FastCopy "дырочный" байт09 для "установки" ключей.
АЛМ 3 теперь игнорирует все FastCopy ключи с установленным служебным байтом 09 =0 (то есть служебной дыркой).
В данном примере используются 2 нормальных ключа с Желтой дискеты, а остальные установлены EKBBackup 2006 07 11 и поэтому игнорируются.
TioPepe
Post by TioPepe » Sun Sep 17, 2006 5:54 pm
Hi BadNews
Thanks a lot for your teaching!!!
Good News
Post by Good News » Sun Sep 17, 2006 9:20 pm
http://files.cvalka.net/index.php?actio ... ry=Simatic&
or
Link_is_Dead :(/Sim ... _09_21.zip
Первая попытка найти выход из сложившейся ситуации после выхода ALM 3.
Образы Желтых дискет соджержат только по 1 ключу.
Из-за того , что времени было мало и делал второпях в образе неправильное имя файла, которое заменяется программой от 16/09/2006
автоматически после форматирования дискеты только в режиме FAST.
Или можете вручную переименовать ключевой файл A:\AX NF ZZ\SIFLA9~1.EKB по имени файла образа.
Для ускорения работы форматирую только несколько начальных дорожек с ключём. Для этого взведите галочку FAST.
После создания дискеты переносите ключ с помощью АЛМ и не вынимая дискету создавайте следующий.
Перед установкой этих ключей удалите быстрокопируемые ключи из каталога C:\AX NF ZZ
В связи с тем, что гибкодисковые операции занимают много времени, то у меня его не хватило для создания дискеты со всеми ключами.
Так как в данный момент я не могу их все проверить - пробуйте и сообщите результаты.
This is special edition of EKB_Yellow_Disk 2006 09 16.exe for ALM 3. Because ALM 3 ignore Long FastCopy keys.
Set checkbox "FAST" for create individual Yellow Disk with only 1 key from this image files.
If not use Fast mode you need rename key in A:\AX NF ZZ\ SIFLA9~1.EKB to name of image file (for ex. SIFLA0SHLA0601.EKB) - this my bug in this image file.
After creation of Yellow disk you can transfert the key by ALM.
Before install these keys need delete FASTCOPY keys from C:\AX NF ZZ
Very Good News
Post by Very Good News » Mon Sep 18, 2006 2:48 pm
Yellow Disk with 133 Normal Long keys (minimum 1,5 hour for install all SlowCopy keys - минимум 1,5 часа для установки всех ключей 133 медленнокопируемых ключей)
and YELLOW FLASH - USB Flash 128 mb image (5 min for install all keys - за 5 минут)
Link_is_Dead :(/Sim ... _09_22.zip
http://files.cvalka.net//index.php?acti ... ry=Simatic&
or
Link_is_Dead :(/Sim ... _09_21.zip 2.9 mb
Перед установкой ключей удалите FastCopy ключи из C:\AX NF ZZ
Before install these keys need remove FastCopy keys from C:\AX NF ZZ
For USB Flash I use http://www.WinImage.com (Name: DNSoft ; Serial Number Prof mode: 105DECFD)
Run WinImage and select destination drive - ANY SIZE and ANY TYPE USB Flash Memory Stick or Compact Flash (I try only CF) ... in the CardReader.
Запусти ВыньИмаж и выбери диск с флешкой любого типа и объёма в USB или картосчитывателе.
See new YELLOW FLASH in http://simatic.net.ru/viewtopic.php?p=6624#6624
eMule Link
Full Step7 v5.4 with SP1
Post by eMule Link » Wed Oct 04, 2006 4:32 am
ed2k://|file|[工控ã?&#129;组æ?&#129;软件].Siemens.SIMATIC.Step7.v5.4.SP1.MULTiLANGUAGE.ISO-TBE-CD1.bin|723508128|8263CC730FE51AE7048C3F4E8725F674|/
ed2k://|file|[工控ã?&#129;组æ?&#129;软件].Siemens.SIMATIC.Step7.v5.4.SP1.MULTiLANGUAGE.ISO-TBE-CD2.bin|448709856|E758B633D587ACAC8EAE4A4A7EBF9E7F|/
Contents of the STEP 7 CDs
CD1/2 (Installation CD)
·	STEP 7 V5.4 incl. SP1
·	Converter for the conversion of TI405 and TI 505 programs
·	Automation License Manager v3.0.0.1
+  FastCopy short key A1710454.ekb SIK/SIMATIC STEP 7-BASIS v5.4
CD2/2
·	SIMATIC iMap STEP 7 Addon
·	Description of the Command Interface
·	Shareware version of Acrobat Reader in five languages, with which you can view and print the supplied manuals
·	Product Notes: "What's New"
·	Product Notes: "New Modules"
·	Product Notes: "Central Installation"
·	Manual: "Getting Started: Working with STEP 7"
·	Manual: "Programming with STEP 7"
·	Manual: "Configuring Hardware and Communication Connections with STEP 7"
·	Manual: "System Modification in RUN Mode via CiR"
·	Manual: "Automation System S7-400H - Fault-Tolerant Systems"
·	Manuals: "NCM S7"
·	Manual: "From S5 to S7"
·	Manual: "Ladder Logic (LAD) for S7-300/400"
·	Manual: "Statement List (STL) for S7-300/400"
·	Manual: "Function Block Diagram (FBD) for S7-300/400"
·	Manual: "Standard and System Functions for S7-300/400"
·	Manual: "Standard and System Functions for TI STEP 7 Converter"
·	Manual: "PID Control"
·	Manual: "PID Temperature Control"
·	Compatibility List
Link_from_CVALKA
Post by Link_from_CVALKA » Sat Oct 07, 2006 4:31 pm
http://www.oxedion.de/index.php/downloa ... 7d14265127
Contact:
Post by CoMod » Thu Nov 09, 2006 1:18 pm
STEP 7 Professional Engineeringsoftware for SIMATIC S7 / M7 / C7
Edition 2006 SR1
Contents of CD 1 STEP 7 Professional Edition 2006 SR1
·	S7-GRAPH V5.3 incl. SP2
·	S7-SCL V5.3 incl. SP1
·	S7-PLCSIM V5.3 incl. SP1
·	Automation License Manager V3.0
This version is from eMule.
Possible (chinese) author of this eMule version CD replace original ALM v3.0 to ALM v2.2 for decide problem with FastCopy key.
6 parts * 90 MB
Link_is_Dead :(/Ste ... part01.rar
Link_is_Dead :(/Ste ... part02.rar 90 mb
Link_is_Dead :(/Ste ... 3.Link_is_Dead :(
Link_is_Dead :(/Ste ... part04.rar
Link_is_Dead :(/Ste ... part05.rar
Link_is_Dead :(/Ste ... part06.rar 71 MB
Contents of CD 2 STEP 7 Professional Manuals
·	WRI file "STEP 7 - What's New.wri"
·	WRI file "S7-GRAPH - What's New.wri"
·	WRI file "S7-SCL - What's New.wri"
·	Electronic manuals for STEP 7 V5.4
·	Electronic manuals for S7-GRAPH V5.3
·	Electronic manuals for S7-SCL V5.3
·	Electronic manuals for S7-PLCSIM V5.3
·	Command Interface description
Description of the Central Installation Procedure
Link_is_Dead :(/Ste ... nglish.rar 25.0 MB
Link_is_Dead :(/Ste ... eutsch.rar 23.9 MB
Link_is_Dead :(/Ste ... spanol.rar 26.9 MB
Link_is_Dead :(/Ste ... ancais.rar 28.8 MB
Link_is_Dead :(/Ste ... aliano.rar 25.7 MB
Link_is_Dead :(/Ste ... _AddOn.rar 23.4 MB iMap 3 AddOn only
I don't want to upload 90 MB of Acrobat Reader
and 97 MB of Hotfix 1 (K5.3.3.1) for STEP 7 V 5.3 SP3 (!?:) from iMap AdddOn folder
But upload full CD2:
Link_is_Dead :(/Ste ... .part1.rar 90 MB
Link_is_Dead :(/Ste ... .part2.rar 90 MB
Link_is_Dead :(/Ste ... .part3.rar 90 MB
Link_is_Dead :(/Ste ... .part4.rar 46 MB
eMule links:
ed2k://|file|[ОчГЕЧУ№¤їШ±аіМ].Siemens.SIMATIC.Step7.Professional.Edition.2006.SR1.MULTiLANGUAGE-TBE-CD1.bin|833715792|4493299BE6DECA50399D86B6EC3335C4|/
ed2k://|file|[ОчГЕЧУ№¤їШ±аіМ].Siemens.SIMATIC.Step7.Professional.Edition.2006.SR1.MULTiLANGUAGE-TBE-CD2.bin|481176864|63F5A5DAD32B7EF9A0631CCBE055322A|/
or CD1+CD2 1.22 GB
ed2k://|file|Siemens.SIMATIC.Step7.Professional.Edition.2006.SR1.MULTiLANGUAGE-TBE.rar|1314905803|CE358CAA00AD9B27EAAA8E6BD49B802B|/
flashy
Post by flashy » Thu Nov 09, 2006 10:44 pm
Hi Peps
Just in process of updating my version with this one, and have just noticed that the Licence manager which is supposed to be V3 is in fact only version 2.2
Can someone else confirm this please...
Best regards
##~flashY~##
Contact:
Post by CoMod » Fri Nov 10, 2006 5:06 am
Oops!
Possible (chinese) author of thise eMule version CD replace original ALM v3.0 to ALM v2.2 for decide problem with FastCopy key.
