[LINK]: KB319740 for setup WinCC v6
alameer
Post by alameer » Thu Aug 24, 2006 3:24 pm
hi
i am install the wincc v6 and sql
but i can't setup on my computer
and this msg apper when setup
("MS Security Patch is not installed on this system.
For this WinCC Version, the following software is required:
WindowsXP SP 2 KB319740
Please run the installation of MS-Security Patch from your MS Tools - DVD.
Operation of WinCC under Windows XP SP2 has been released for WinCC with deactivated firewall only.
You must deactivate the firewall manually.
i hoppe from any one in this fourm setup on your computer and suport by image for instlation
thanks
flopez
Re: how setup wincc v6
Post by flopez » Thu Aug 24, 2006 3:43 pm
alameer wrote:hi
thanks
hi
look at this link
http://simatic.net.ru/viewtopic.php?t=9 ... ight=wincc
or
Your Download-Link #1: Link_is_Dead :(/files/30600498/KB319740.zip.html
flopez
Post by flopez » Thu Aug 24, 2006 4:05 pm
alameer wrote:thank u flopez
this page weiten by russin
i need english page
use translactor in http://babelfish.altavista.com/
I don't also know Russian, look the link at download of the file KB319740 later it is only to execute
flopez
Post by flopez » Thu Aug 24, 2006 6:37 pm
alameer wrote:------------------------------
(.YuKEY_.LOccAL_.MAccYuINE\.SOFTShARE\.Michrosoft\.Updates\.Shindoshs
XP, we there create division SP3, and further, in SP3 we create
division KB319740.)
where put this file
i have windos sp2
1º - To create one file with nome.reg
2º- Edit file nome.reg
3º- To add file these lines of text
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Updates\Windows XP\SP3\KB319740]
4º - To save file
5º - To execute file that you are created to clikar two times in file
Or as it above said to make download of file that this zip in
I wait that it is util
alameer
Post by alameer » Thu Aug 24, 2006 7:05 pm
thank you
i hope join with you
alameer622@hotmail.com
Guest
Post by Guest » Sat Sep 09, 2006 3:07 pm
For Russian Windows XP
Для русской ХРюни
http://files.cvalka.net//index.php?acti ... ry=Simatic&
or
я не знаю почему и как Но с Рапиды её удаляют через несколько дней автоматом :cry:
other language in
http://www.cakewalk.com/Support/kb/kb2005243.asp
