MPI.PPI.PROFIBUS To TCP/IP Converter
Guest
Post by Guest » Fri Aug 18, 2006 2:50 am
Technical Data
Ethernet Interface
Transmission rate 10 / 100 MBit/s
Interface 10 / 100 Base-TX, isolated
Connector RJ45 PLUG
PROFIBUS Interface RS485, max 12 MBaud, optically isolated
according to EN 50170
Power Supply +24 V / 50 mA
Operating Temperature 0 °C - 50 °C
Safety Type IP 20
Dimensions (L x W x H) 65 x 48 x 16 mm
Weight ca. 140 g with cable
Do anybody can DIY it?
Guest
Post by Guest » Fri Aug 18, 2006 5:58 am
you found Netlink by HILSCHER
http://www.hilscher.fr/products_details ... 024bb&bs=5
beware: you need the ppi/mpi/profibus-dp driver ibhnet
