[Link]: Step7 MicroWin V4.0 SP4
flopez
Post by flopez »
Hello Personal Here it is going link to Step7 MicroWin V4.0 SP4
http://support.automation.siemens.com/W ... d=23544932
After Download expand the Files in a new Folder and
change the setup.INX Files
Your Download-Link: http://rapidshare.de/files/29748447/setup.inx.html
One more option for installation completes of the file STEP7-MicroWIN_V40_SP4.exe
For who doesn't want to substitute the file setup.inx there is this.
Before installing the file STEP7-MicroWIN_V40_SP4.exe
To create a file with the extension reg (nome.reg)
To edit that file with an editor WorPad and to increase these text lines
[HKEY_LOCAL_MACHINE\Software\SIEMENS\MicroSystems\Common\Update320]
[HKEY_LOCAL_MACHINE\Software\SIEMENS\MicroSystems\Common\Toolbox\Components]
"CountLibs"=dword:00000001
to join to the register windows
It only remains a good luck for the installation.
Information……
If it edits the file Setup.inx the following he/she can se
.'...#..........!.............!........UPDATE_FOUND.......................!.2...........!...........Microwin.exe..................
!...........s7200.exe..................!.]......!......>...!.J........!........COMPANY_NAME.......
.............Software................Common.............Update320!.D.........!..
By Flopez
Maxime
Step7 MicroWin V40 SP4
Post by Maxime »
Does anybody has by chance a key for S7 MicroWin V40 SP4???
thnx
flopez
Re: Step7 MicroWin V40 SP4
Post by flopez »
Maxime wrote:Does anybody has by chance a key for S7 MicroWin V40 SP4???
thnx
hello
before installing the s7-200 MicroWin V4.0 SP4, to unite this file to the register of the Windows XP http://rapidshare.de/files/37268714/S7200V4.0.reg.html
it excuses if I am not to explain well but I don't know English well
flopez
Scowl
Post by Scowl »
Files S7200V4.0.reg and setup.inx at rapidshare.de has been deleted. Could anybody reupload them?
http://files.cvalka.com directory Simatic
MicroWin_3_and_4.zip
62.67 Kb
Scowl
Post by Scowl »
они пойдут для SP4?
Если судить по названиям - то да.
Насколько я помню для России Микровин вообще бесплатен.
TheNewS7
SP5 is out now!
Post by TheNewS7 »
Download MicroWIN 4.0 SP5 from Siemens Support:
http://support.automation.siemens.com/W ... d=24676877
Download place for the setup.inx file: www.cvalka.com
Start the Setup and go to your lokal\Temp folder, wait up the language Dialog from Setup and save the complete new folder on an other place.
There after you can abort the setup.
Replace the setup.inx file with the new file and start the setup again...
PS: if anybody have the orginal Siemens Font from URW++:
Siemens Sans, Siemens Serif or Siemens Slab,
please publish it.
Thanks, the new s7.
