Request: NAIS FPWINPro 5.1.01 Full Version File
другие контроллеры
brave_eagle
Post by brave_eagle »
Pls. copy these two files to your FPWINPro main directory replacing the original files, thenyou can enjoy a full version FPWINPRO
Delete by timeout wrote:FPWINPro_Version_Full_Files_5.101.zip
If you want to get onther NAIS software, FPWIN GR, GTWIN........
Pls. reply this topic
Good Luck
Galli
Post by Galli »
You can download FPWinPro5.10 and version 5.22 from Nais (Panasonic) website.
Here the medicine --> FPWINPro5.0_crc.rar
http://www.cvalka.com//index.php?&direc ... ry=Simatic
or
http://plcforum.uz.ua//FP ... c.rar.html
Procedure --> follow the instruction for s7-200, same procedure.
http://www.plc.net.ru/viewtopic.php?t=5843
I tested, its working.
gremlin
Post by gremlin »
how do you use this .inx file ?
when i search my c: drice for setup.inx after runing the demo download from panasonic site i dont find any setup.inx to swap with downloaded file to be able to run again the setup ?
i am using windows XP sp2
thanks
gremlin
Galli
Post by Galli »
As s7-200,
Start the Setup and go to your lokal\Temp folder, wait up the language Dialog from Setup and save the complete new folder on an other place.
There folder may be created in the following directory..
(I think \Windows\Temp, or Document Settings\Admin\Temp )
Thereafter you can abort the setup.
Replace the setup.inx file with the new file and start the setup again
Galli
Post by Galli »
Dont download the demo file..
Download the full version 5.xx
and the upgrade file 5.22...
After swap the .inx, then upgrade to 5.22
gremlin
Post by gremlin »
Got it sorted !
thanks
temp folder was in stupid place due to network config
all the best
gremlin
niila
Post by niila »
hi galli..
There are only version 5.101 ,for upgrade 5.0 to 5.101, and 5.22 demo version on panasonic website..
where is the full version? :roll:
Galli
Post by Galli »
Last time have ...
niila
Post by niila »
hi galli..
thanks a lot for info,I was heedless of this software..
I downloaded fpwin 5.10 difference file and 5.22 difference file but those files are most likely for upgrade because ;
mew(panasonic website) says ;
Panasonic wrote:''The Control FPWIN Pro Ver.5.22 difference file is used to upgrade Control FPWIN Pro Ver.5.1 or later to Ver.5.22.
This file does not work on its own.
To install this software, Control FPWIN Pro Ver.5.1 must already be installed''
and when I had installation to 5.10 difference file it requests version 5 :roll:
Galli
Post by Galli »
If follow the above procedure,
I got something like this, with the above serial number, username, etc..
niila
Post by niila »
hi galli..
thanks a lot..I solved.That's great... :lol: also; after installation I restarted to computer and computer gave me;update error(invalid data) is it normal?
fatech
Help again
Post by fatech »
Hi Galli,
When I do your direction, Program notice will setup the Full version.
But when it needs the serial, I type any serial, program notices the wrong serial, so i type the same serial in the notepad file, it continues.
When program need choose the destination folder as C:\Program Files\Nais Control\FPWin Pro 5, I choose OK, it notices
Error Number : 0x80040706
Description : Object reference not set
Setup wil terminate
Please help me solve this problem
Many Thanks
Galli
Re: Help again
Post by Galli »
fatech wrote:Hi Galli,
Setup wil terminate
Many Thanks
Honestly I dont know what yr error code stand for and fix that problem..
I only have an idea how to install FPWin Pro 5.10 afterI read the s7-200 procedure..
This procedure may apply to MELSEC software as well, I think..
saad rashed
FPwinProV5.22 FULL
Post by saad rashed »
