[LINK]: Serial number SIMOCODE ES Professional 2004+SP3+HF1
Ikke_
Post by Ikke_ »
SIMOCODE_ES_Professional_2004_SP1
(mirr) https://disk.yandex.ru/d/qA3JuMSnuSSXNA/SIMOCODE_ES_2004
serial for "SIMOCODE ES Professional 2004 + SP1".
Siemens wrote:SIMOCODE ES is the central software for parameterization, configuration and diagnostics of SIMOCODE pro.
Russian Info
[dead] http://www.automation-drives.ru/cd/products/1/protect/simocode/
SIMOCODE-DP- "интеллектуальная" связь между пусковой комбинацией для двигателя и системой автоматизации.
The new s7
modified exe
Post by The new s7 »
Download the modified Executable for Simocode ES Professional 2004+SP1
under cvalka_com (cvalka_net) [dead]
Go to the Bin Directory from SWITCH ES and replace the nsappnsx.exe with the given.
One Bitmap are modified, and the second Bitmap was deleted.
or Serial number for SIMOCODE ES Professional 2004 + SP1 :
20844-0001-000133
From CVALKA
Post by From CVALKA »
Deleted by TimeOut [dead] Simocode_ES_Professional_2004_SP1.zip (771918 Bytes)
Simocode_ES_Professional_2004_SP1_patch.zip
tgl
Re: modified exe
Post by tgl »
The new s7 wrote:Download the modified Executable
This, however, does not allow for Hotfix2 installation
Это, однако, не дает возможности установить Hotfix2 :)
ead2006
Not Work....HELP ME!!!!
Post by ead2006 »
From CVALKA wrote:Simocode_ES_Professional_2004_SP1.zip (771918 Bytes) is now online.
Your Download-Link: ....Simocode_ES_Professional_2004_SP1.zip
Hello
I have downloaded and treaty to install this Simocode_ES_Professional_2004_SP1.zip,
but not install, appear a message that say:
First should to install Simocode ES Professional.
Please I need the software (Simocode ES Professional), exist a linsk from may I download it...?
Thank very much for help me advance
Pietia
Simocode ES
Post by Pietia »
May you put tis file somewhere again? It is deleted form rapidshare.
BR
Pietia.
ReUpload
Post by ReUpload »
Delete by TimeOut wrote:Simocode_ES_Professional_2004_SP1_patch.zip
The modified Executable for Simocode ES Professional 2004+SP1
under cvalka_net [dead]
или используйте Серийный номер
20844-0001-000133
Серийный номер для SIMOCODE ES Professional 2004 + SP1: 20844-0001-000133
Как получил.
Программой SID дизассемблировал файл setup.inx. В получившемся тексте нашел интересный код:
Serial number for SIMOCODE ES Professional 2004 + SP1: 20844-0001-000133
How I got it.
I disassembled the setup.inx file with the SID program. In the resulting text I found an interesting code:
@000103CF begin
@000103D8:0006 local_string1 = "SerialNumber";
@000103EE:0021 _GetStringFromRegFile(local_string1, local_string2);
@000103FA:002C StrToNum(local_number3, local_string2);
@00010404:000F local_number3 = (local_number3 - 123456789);
@00010413:002D NumToStr(local_string2, local_number3);
@0001041D:0029 StrSub(local_string3, local_string2, 0, 5);
@00010431:0006 local_number1 = LASTRESULT;
@0001043B:0006 local_string4 = local_string3;
@00010445:0029 StrSub(local_string3, local_string2, 5, 9);
@00010459:0006 local_number1 = LASTRESULT;
@00010463:0007 local_string5 = (local_string4 + "-");
@00010471:0007 local_string5 = (local_string5 + local_string3);
@0001047E:0007 local_string4 = (local_string5 + "-");
@0001048C:0021 StrLength(global_string29);
@00010495:0006 local_number2 = LASTRESULT;
@0001049F:0009 local_number4 = (local_number2 < 17);
@000104AE:000A local_number5 = (local_number2 > 17);
@000104BD:0018 local_number4 = (local_number4 || local_number5);
@000104CA:0004 if(local_number4) then // ref index: 1
@000104D6:0027 // return coming
@000104DA:0023 return 0;
@000104E3:0005 goto label_1054a;
@000104EC:0007 endif;
Из него ясно, что всего в введенном коде должно быть ровно 17 символов, цифры внутри разделены двумя знаками "-".
И тут я вспомнил, что похожий серийник промелькивал на этом или санином форуме (20834-0001-000133). Однако этот код программа не приняла. Нашару попробовал поменять каждую цифру на +/- 1. и вот удача.
кряки со свалки теперь не нужны...
Вывод: кто ищет - тот всегда найдет.
Всем удачи!
It is clear from it that the entered code should contain exactly 17 symbols, the numbers inside are separated by two "-" signs.
And then I remembered that a similar serial number flashed on this or Sanya's forum (20834-0001-000133). However, the program did not accept this code. Nashu tried to change each digit to +/- 1. and here is luck.
No need for cracks from the dump now...
Conclusion: he who seeks will always find.
Good luck to all!
Hotfix 2
Hotfix 2 for SIMOCODE ES 2004+SP1
Post by Hotfix 2 »
[dead] http://support.automation.siemens.com/WW/view/en/22128232
Hotfix 2 for SIMOCODE ES 2004+SP1 ( 8251 KB )
[dead] http://support.automation.siemens.com/W ... tfix_2.zip
Full SIMOCODE ES 2004 + SP1 (54.3 mbyte)
Delete by TimeOut wrote:SIMOCODE_ES_Professional_2004_SP1.zip
Service Pack 3
Service Pack 3 (SP3) for SIMOCODE ES Smart 2004 / SIMOCODE ES Professional 2004
DESCRIPTION:
The Service Pack 3 (SP3) software for SIMOCODE ES Smart 2004 and SIMOCODE ES Professional 2004 is now available for download. This download software will upgrade an existing and registered installation to SIMOCODE ES Smart 2004+SP3 or SIMOCODE ES Professional 2004+SP3.
I don't know why, but these links deleted by Siemens - you can't download SP3
but foday 13/12/2006 reopen links with SP3+HF1
[dead] http://support.automation.siemens.com/WW/view/en/24064090
[dead] http://support.automation.siemens.com/W ... 04_SP3.zip 66,429 MB
ruudoleo
simocode es
Post by ruudoleo »
rapidshare links are dead
can someone reupload the simocode pro es software
i can upload the simocode dp version if someone needs it
thanks
Service Pack 3 incl. Hotfix 1 (SP3+HF1) for SIMOCODE ES Smart 2004 / SIMOCODE ES Professional 2004
Link
Forum Community
Forum Community
Post by Link »
Reuploaded
SIMOCODE ES Professional 2004 + SP1 55334 KB
http://plcforum.uz.ua//SI ... 04_SP1.zip
Re: [LINK]: Serial number SIMOCODE ES Professional 2004+SP3+HF1
[dead] SP3
