kazzuro
Post
by kazzuro » Mon Jul 03, 2006 7:40 am
have you ever used
S5/S7 Doctor from IBH Softec?
I had a demo version and I used it for S5 programmes. I think that it is great for reversed engineering. Unfortunatelly, it has only 14 days trial period and there is no way to connect to PLC online. So I am looking for
S5/S7 Doctor in full version. Do yu know where can I find it?
Or maybe you know
other similar programs?
Thanks in advance!
http://www.ibhsoftec-sps.de/english/first.htm
Link
- Forum Community
- Location: We are anonymous users. We do not read your private messages :( Ask questions in the forum !
Contact:
Post
by Link » Mon Jul 03, 2006 11:00 pm
Hello Kazzuro, am sending this link with the program, leaning that is this that you seek.
this works without code, I tested with CPU S7-314-2DP and he/she works in online.
happiness.
Link_is_Dead :(/S7 ... _crack.rar
include Ibh_Softec_s5W_v5-06_Full_Eng_.rar with crack
ppp
Post
by ppp » Tue Aug 01, 2006 5:18 am
sraiderk
Post
by sraiderk » Thu Nov 23, 2006 8:03 pm
I installed S5/S7 Doctor v2.23 that was downloaded your link.
Afterthat I made everything in the readme file. But, program is still in demo mode.
Because I use the help->info about S5/S7 doctor toolbar, then It gives the demo information.
Is it in demo mode or not?
Contact:
Post
by CoMod » Thu Nov 23, 2006 8:46 pm
from README
Only english version is cracked!
During installation choose english language.
Install "S7-Doctor" as "DEMO".
After installation copy "Run S7-Doctor.exe" to program folder.
For using S7-Doctor without any limitations start "Run S7-Doctor.exe".
I try. Only diference - no registration window when Start.
Единственное отличие - нет окна регистрации при запуске.
But / Ho
Инсталлируйте "S7-Doctor" как "ДЕМО". После инсталляции скопируйте файл "Run S7-Doctor.exe" в каталог установки. Для использования S7-Doctor без всяких ограничений запускайте "Run S7-Doctor.exe".
Крякнута только английская версия! При инсталляции выберите английский язык.
henk
Post
by henk » Thu Nov 23, 2006 10:17 pm
IT WORKS!!!!!!
Thanks.
Henk
sraiderk
Post
by sraiderk » Mon Nov 27, 2006 5:34 pm
CoMod,
I apoligize from you. You are right. It works on my other pc. But, this pc still has problem. Of course this is my problem. Thanks...
KoliaMor
Post
by KoliaMor » Thu Nov 08, 2007 1:01 pm
I need help!!!!!
S5 S7 Docrot under runing generated ERROR:
<Instruction at adress 0x00404a79 call to memory at adres 0x00000018
Memory cannot written>
OS - Widows XP SP2 with Microsoft. NET Framework 1.1
What is problem.
Link
- Forum Community
Contact:
Post
by Link » Fri Aug 29, 2008 4:44 pm
Link
- Forum Community
Contact:
Post
by Link » Mon Mar 02, 2009 2:02 am
S5 S7 Docrot V2.25
English // German
rapidshare S7_Doctor_225.zip
venix
Post
by venix » Wed Mar 04, 2009 8:28 pm
Does anybody succeded to connect online with this software?
I tried and with no succes.I am using a USB-Serial adapter.
With S5/S7 for Windows I had no problem,also with PG2000.
Best regards,
Venix
dekor
Post
by dekor » Thu Mar 05, 2009 7:32 am
I use for connection a USB-RS232 adapter. I use this soft also with this adapter.
Check on manufacturer web site.
Check on this link :
http://apple.clickandbuild.com/cnb/shop ... tle=UC232R
The manufacturer has a local distributor also in your country.
dekor
kiran kalburgi
Post
by kiran kalburgi » Sat Jan 16, 2010 11:04 am
kazzuro wrote:Hello,
have you ever used
Or maybe you know
Thanks in advance!
http://www.ibhsoftec-sps.de/german/Doctor_1.htm
http://www.ibhsoftec-sps.de/english/Doctor_1.htm
Hello can u tell me how can i add a new GSD file to this S5/S7 Doctor
rajume06
Post
by rajume06 » Sun Oct 26, 2014 10:07 pm
Dear Link,
All rapidshare link are dead. and i can't download from narod.ru, because i don't know download procedure from this site. Please tell me how can i do this? or another link.
Thanks in Advance
eng_no1
Post
by eng_no1 » Fri Mar 03, 2017 2:40 pm
links not work please update
autosystem
Post
by autosystem » Tue Jan 09, 2018 5:36 pm
download link is corrupt, please upload file again. thanks
Nedjeljko
Post
by Nedjeljko » Wed Mar 14, 2018 9:59 am
Can someoen reupload somwhere this tool?
Thank you in advance.
ATech
Post
by ATech » Thu Apr 05, 2018 1:34 pm
Please update the download link. Thank you!
winice
Post
by winice » Fri May 11, 2018 8:36 am
invigo
Post
by invigo » Sat May 11, 2019 9:54 am
