Hallo,
Is DRIVE ES BASIC V.5.4 available for download?
Where can I find it?
sandy
[LINK]: DriveES Basic V5.4
Compatability Chart for Technology Elements of DriveES.
![Image](http://img287.spamm.us/img287/2131/driveesstep74re.gif)
![Image](http://img176.spamm.us/img176/5923/driveespcs76cl.gif)
The reasons for the revision and further development are the market launch of STEP7 V5.4 and expanded functionality of the integrated commissioning tool.
The following innovation points were introduced:
Fully compatible to STEP7 V5.4
Starter Version V4.0, the commissioning tool for SINAMICS and MICROMASTER 4th Generation is integrated.
SimoCom A Version V 04.03.00 - the tool for POSMO A is integrated.
SimoCom U Version V 09.02.04 - the tool for SIMODRIVE 611U and POSMO CA/CD/SI is integrated.
New DriveMonitor Version V5.4 - the tool for MASTERDRIVES and SIMOREG is integrated.
Used under the operating system Windows Server 2003 from SP1
New features of the integrated DriveMonitor V5.4:
Now, an OPC interface is also available as communications channel
Now, all offline parameters can be selected as permanent function in the navigation tree of the free parameterization
Support, new FW versions V2.4 for MASTERDRIVES MC and MC Compact Plus
Support, new FW versions V2.2 for SIMOREG DC Master and SIMOTRAS 6SG70
Support, new FW versions V10.4 for SIMOVERT S and V20.8 for SIMOVERT MV
Support, new FW versions V2.1 for MICROMASTER MM440
New features of the integrated Starter V4.0:
Now, the new Starter V4.0 ( V4.0.0.x ) supports the following drive systems:
All drive units belonging to MICROMASTER 4th Generation (new: MICROMASTER 440 V2.1x)
SINAMICS G110 with firmware V1.0x and V1.1x
SINAMICS G120 with firmware V2.0.x
SINAMICS G130 with firmware V2.1x, V2.2x, V2.3x and V2.4x
SINAMICS G150 with firmware V2.1x, V2.2x, V2.3x and V2.4x
SINAMICS GM150 with firmware V2.4x
SINAMICS S120 CU320 with firmware V2.1x, V2.2x, V2.3x and V2.4x
SINAMICS S120 CU310 DP and SINAMICS S120 CU310 PN with firmware V2.4x
SINAMICS S150 with firmware V2.1x, V2.2x, V2.3x and V2.4x
SIMATIC ET200S FC with firmware V1.0x
Additional information about the integrated Starter Version V4.0 is available under ProdIS-ID: !23049727!
The integrated commissioning tools can also be individually downloaded from the Internet and in this way can be used to upgrade an existing Drive ES Basic V5.3 SPx installation at no charge.
How do I receive the new version?
Order the new version!
All orders will be available with this release for general availability. The price remains the same.
For users that already have a version of Drive ES Basic V5.x!
These users can order the upgrade version that is available at a significantly lower price than the full version.
For reasons relating to memory space, the complete Drive ES Basic CD V5.4 cannot be downloaded.
It can only be ordered using the upgrade version that is available at a significantly lower price than the full version.
For customers that already have an update service contract 6SW1700-0JA00-0AB2 or 6SW1700-0JA00-1AB2!
The new version will be automatically sent to customers who have an update service contract.
Compatibility:
Windows 2000, XP Professional incl. SP2 and Windows Server 2003 from SP1
STEP7 V5.2 SP1 as well as STEP7 V5.3 SPx and STEP7 V5.4
Compatibility:
Re: Compatability Chart for Technology Elements of DriveES.
Drive ES Basic v5.4Compatible wrote:Compatability Chart for Technology Elements of DriveES
This fine, but where I can find the link?
If possible.
Если возможно, может есть где-нибудь ссылка, на этот замечательный софт?
See link in http://plc.net.ru/viewtopic.php?t=4845
