[LINK]: OLD VT100 ESA (for MS-DOS only)
Hello personal I needed a program to work with the terminal VT100 ESA
leaning that the name of the program is VTEDS or VTPROG this works in the system MS-DOS
Thank you
flopez
Thank you
flopez
HELLO Flopes, i have uploaded a old vt software. I dont know, if this sw it's ok for vt100.
I have also anther software for VT100 for Dos, but this VT100 is supplied from EFA automation , not ESA.
If you need also this , please sand a request message.
Enjoy
link
Link_is_Dead :(/files/23306677/VT-ESA.ZIP.html
Enjoy
link
VTProg per VT100
Hello PLC_ITA at once mine thank you, for you have facilitated the download of the program.
I inform that this is working very well.
Italiano
Ciao PLC_ITA subito i miei La ringraziano, per Lei ha facilitato lo scarichi del programma.
Io informo che questo sta funzionando molto bene.
Cumprimentos
Flopez (hihihihihi)
Italiano
Cumprimentos
Flopez (hihihihihi)
- Forum Community
- Location: We are anonymous users. We do not read your private messages :( Ask questions in the forum !
- Contact:
Link VTProg_ESA for MS-DOS
kemal4551 wrote:"Link_is_Dead :(/files/23306677/VT-ESA.ZIP.html" is deleted. Can you re-upload.
Best regards
File: VTProg ESA.zip
DownloadLink: Link_is_Dead :(/VTProg_ESA.zip
File: Esa_VTWin_4_79
Link_is_Dead :(/Es ... .part1.rar
Link_is_Dead :(/Es ... .part2.rar
Link_is_Dead :(/Es ... .part3.rar
Link_is_Dead :(/Es ... .part4.rar
Link_is_Dead :(/Es ... .part5.rar
The Prog. VTProg of the ESA alone functions in Operative System MSDOS 6.20 or 6.22kemal4551 wrote:Thank you very much flopez. But I could not install (winXP_SP2).Message is"Not legal path C:\Vtprog..."
How can i install vtprog
Best regards
I go to verify if other Prog. of the ESA that works in the environment of the Windows if it has drivers for the panel that you relate
Flopez
cable VT100---PC
DB 25 MALE -----VT100 ---VT420?? DB9 FEMALE RS232 PCkemal4551 wrote:Hi
Flopez I installed the program (VT-EDS) thanks now I repuire VT <=> PC programming cabels schema for vt420 and vt600. Can you share if you have it.
Best regards.
2---------------------------------------------2
3---------------------------------------------3
7 ----┐---------------------------------------5
25 ---┘ ┌----------4
4--┐ └----------6
5--┘ ┌-------------------7
15--┐ └-------------------8
18--┘
malha-------------------------------------malha
vt600 program menu missing
Thanks for VTEDS uploading but I have a problem,
I need to connect to a VT600,
I installed succesfully VTEDS
but when opening VT600 programing menu it tells
Every HMI programing menus till VT500 series works, just VT600 is missing,
Are there any complement or aditonal disk?
Could you help me? Thanks in advance
"not installed".
Re: [LINK]: OLD VT100 ESA
Hi Guys,
I would just like to ask help on how to successfully install the VTPROG software in my system. I will be trying to read an existing ESA program for a VT100 panel. First, I have downloaded the VTPROG installation files using the rapidshare link posted then I tried to extract all of them. After that, I install it under Windows XP SP 3 OS using DOSBOX emulator but I am always encountering an error "Not Legal Path C:\VTPROG". Would you be so kind to send me a procedure that I can follow to successfully install it? That would be very very very helpful.
Many Thanks and Happy New Year to Everyone!
Hello, for you to have good success with the program installation, you'll need to install the PC in MSDOS 6.0 or 6.22, as with the MSDOS emulator Windos XP this program does not work.
flopez
flopez
Re: [LINK]: OLD VT100 ESA (for MS-DOS only)
Hi there,
I´m looking for EFA Automazione FLY 55 - FLY 240 programming software, does anyone have it?
Many thanks.
c0den.
Many thanks.
c0den.
I have the same problem with installing. So this program only works with DOS 6 or 6.22 not through DOS BOX?
I tried the install from dosbox and dos 6.22 but still run into to same error! Please help me anyone with what you learned on how to configure the install. I believe I may not have the .bat file corect or something else becouse I get the path error or if I try to launch an old created program it gives me an ERROR "File VT400.INI not enabled."
Hi Guys,
Link_is_Dead :(/VTProg_ESA.zip is deleted. Can you re-upload.
I need to connect to a VT520G
Mick
Mick
Can you re-upload please?
