[INFO] plcforum temp adress
"Ваш домен plcforum.uz.ua не продлен
Доменное имя plcforum.uz.ua требует продления."
Зеркало адреса https://plcforum.uz.ua
new adress https://plcforum.uz.ua
Re: [INFO] http://plcforum.ml temp adress
it also could be :
put this line in C:\Windows\System32\drivers\etc\hosts
5.29.158.219 plcforum.uz.ua
and run ipconfig /flushdns in cmd
wishes everybody come back soon.
plcforum.uz.ua is active again
please use plcforum.uz.ua
save the link https://plcforumuzua.blogspot.com/ for check status with forum access problem
[INFO] http://plcforum.work.gd temp adress
регистрацию plcforum.uz,ua каждые 2 года надо продлевать...
но в этом году пока не получилось...
запустили https://plcforum.uz.ua/
имена фамилии явки прежние
plcforum.uz.ua registration needs to be renewed every 2 years...
but this year it didn't work...
launched https://plcforum.uz.ua/
all logins work
all logins work
Re: [INFO] plcforum temp adress
A little bit precisation:
from IT the domain as above is unavaiable but with the direct ip address 77.138.222.180 is showing the home page, but after a login (the logins data are saved!!) the browser point again to resolved address, with the above errors, but if sobstituting the resolved address with the above ip address the forum (with login credentials) is showing ...
Is the DNS problem solvable?
A bit more checks:
plcforum.uz.ua resolve correct to 77.138.222.180
but
https://plcforum.uz.ua cannot resolve
is possible to add a line to this DNS record for resolving also http:// ?
Regards
but
Regards
I tried to mak lik this but it's not working please support
Please support i can't open the forum all tried
"http://" it isn't part of DNS record, but point to protocol & port used only
for check availability please follow to this tools
https://www.uptrends.com/tools/uptime
https://www.uptrends.com/tools/dns
for example traceroute from Milano to https://plcforum.uz.ua come within 85ms to right IP (77.138.222.180)
Hello Sania,
both PING and TRACERT works flawless, givimg me back the right IP resolved 77.138.222.180 (I think at this point that is the only website on this webserver)
I've found the point: my antivirus tell me that this domain is infected by BotNet ...
this is a scan by another authority
https://www.urlvoid.com/scan/plcforum.uz.ua/
clean ...
sorry for the trouble
clean ...
it`s because new domain & have no reputation.
our old domain was worked from around 2015.
but for sure, it`s the old forum, old physically server, old DBs, nothing not changed except domain name.
P.S. add our discussion to https://plcforumuzua.blogspot.com/
Effective from 26.05 we will back to our old https://plcforum.uz.ua.
https://plcforum.uz.ua still for BACKUP only
Registration end.... Again...
all logins work
all logins work
It has been many days reconverting,
please consider put backup domain and blog in ekb release.
I guess many friends will check rutracker for forum status.
Good luck to all!
Good luck to all!
Effective from 03.06.24 we will back to our old https://plcforum.uz.ua.
http://plcforum.work.gd still for BACKUP only
