Посмотри
http://simatic.net.ru/viewtopic.php?t=2 ... c&start=15
Link_is_Dead :(/files/18504965/Sim ... w_Disk.zip 0,5 mb
Renamed Keys for Simatic NET 2005 v6.3
A9SHLA90.ekb SIK/SIMATIC NET S7-REDCONNECT
A9SNEL90.ekb SIK/SIMATIC NET IE SOFTNET-S7 Lean
A9SNEP90.ekb SIK/SIMATIC NET SOFTNET IE PG
A9SNEX90.ekb SIK/SIMATIC NET IE SOFTNET-S7
A9SCBAN0.ekb SIK/SIMATIC Ind. Ethernet PN CBA OPC-Server V6.3 (Renamed or Cracked)
A9SD5290.ekb SIK/SIMATIC NET SOFTNET-DP PB (Renamed or Cracked)
A9SDPS90.ekb SIK/SIMATIC NET SOFTNET DP Slave (Renamed or Cracked)
A9SF5290.ekb SIK/SIMATIC NET PG-5412 (Renamed or Cracked)
A9SNMPN0.ekb SIK/SIMATIC NET OPC-Server-S7 Basis (Renamed or Cracked)
A9SNMUN0.ekb SIK/SIMATIC NET OPC-Server-S7 PowerPack V6.3 (Renamed or Cracked)
A9SNMXN0.ekb SIK/SIMATIC NET OPC-Server-S7 Extended (Renamed or Cracked)
A9SODXN0.ekb SIK/SIMATIC DX OPC-Server V6.3 (Renamed or Cracked)
A9SS1390.ekb SIK/SIMATIC NET Industrial Ethernet-S7 Extended (Renamed or Cracked)
A9SS5290.ekb SIK/SIMATIC NET PROFIBUS-S7-5412 (Renamed or Cracked)
A9SSPIN0.ekb SIK/S7/SR Ind. Ethernet SOFTNET-S7 V6.3 (Renamed or Cracked)
You can istall by Siemens.exe
or can install from Yellow Disk maded by EKBRename from image *.IMA
Можешь установить ключи Сименсом.ехе
или сделай Жёлтую Дискету из образа IMA с помощью EKBRename и при установке программы вставьте дискету с ключами.
