Hello to all i need to build a simple automation using a Schneider Tm221 and premium HMI by asem
I need to read some bit from plc and create into hmi a "led" green or red using the bit value
...very very simple
I know that it's possible to use a modbus tcp communication but i have'nt expirience in tm221 and related sw.
I have install SOmachine basic, and connect the plc succesfully. Also hmi are connected ( i hope ) correctly with the plc ( the communication test into HMI send me a succesfully message )
I know the Premium HMI but it is a first time to use a modbus tcp communication
Any one can suggest me how read an input example %I0.0 and sent to hmi via modbus tcp . I need also the correct sintax to read from hmi a bit or word
I have use 2 day's but no result
Thank you to all in advance
Premium HMI 5_0 and Schneider tm221
PLC_ITA
