[Request] Wincc Advanced V14 Runtime
ricc
Hello to all, someone can posted a link for Wincc Advanced V14 runtime?
optoel
Re: [Request] Wincc Advanced V14 Runtime
Hi to all,
I also need this.
WinCC Runtime Advanced V14 SP1 won't install without havingWinCC Runtime Advanced V14 installed first.
Or there is a way to install SP1?
Please reply if you have any info on this.
I also need this.
Rex2701
You can block unnecessary SP1 requirement in InstData\Resources\SIA2.ini
Find next string in the file:
and put a semicolon in front of it. Like here:
{Registry};{HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\Automation\_InstalledSW\HMIRTM_V11\RT_Adv\Release};{REGSZ};{>=};{14.0};{TermMessage29};{1}Code: Select all
;{Registry};{HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\Automation\_InstalledSW\HMIRTM_V11\RT_Adv\Release};{REGSZ};{>=};{14.0};{TermMessage29};{1}-
optoel
Yep, it works. Thank you!
igormf
worked WONDERS. Thanks
Arthanys89
I have to say you're the best!!!
You've saved me a lot of time!!!
